Joseph,
It will be the reed valves need replacing. When they fail it can create a suction as the piston returns. This, in turn, pulls the recoil handle out of your hand (and can damage the recoil too.)
The Reed Valves are located behind the carb and are easy to replace. Be sure to replace the gaskets on the reed valves and the 2 gaskets on the carb, as they will split when you replace the reed valves. If you use a split gasket, it can allow extra air into the fuel mixture, and result in the engine running rough or not at all. So best to change them as you go.
Best of luck. Let us know if you need any more assistance.
Regards
Generator Guru Parts and Spares
BTW... We sell the reed valves and the gaskets! You can purchase them here:
http://www.generatorguru.com/storm-cat/?sort=featured
