HTC G1 Logo
Posted on Oct 12, 2009
My g1 wont turn on but if i charged it and try to turn it on it would vibrate but the screen is still pitch black
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 30, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
463
Points
Anonymous
Level 1:
New Friend:
  • Posted on Dec 31, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
463
Points
So..i had jst got a warrantee on my g1...and recieved it today..but it will not turn on..could u help?
I plugged in my HTC g1 and it just vibrates and won't turn on.
try to complete the charging process before you power in your phone
Sep 07, 2011 • HTC G1
Hi, I have bought this G1 from Ebay, dont know what is wrong with it. when turn on it vibrates & screen remain blueish black, I tried to Factory reset it. everytime you hard reset it, it gives...
HOpe you did the hard reset by pressing and holding home +power and then alt+w .
Does pressing and holding camera and power gives you the bootloader ( Hboot ) screen . IF yes , try reset from there .
ALso CLick HERE for more details .
Aug 06, 2011 • HTC G1
Ok so i got a G1, and the problem is it wont turn on. even when i charge it, it wont turn on. The farthest it goes it to opening where it says G1 and then it turns off after that. Whats wrong with it, do i...
Try hard resetting it once. But make sure you have enough charge. But this will erase everything.
To perform a Hard Reset
  1. Turn the phone off. If it is frozen, take the battery out and put it back in.
  2. Hold the Home and Power keys down at same time for about 25 seconds. You will see a yellow triangle screen with exclamation point in the middle.
  3. Press Alt+L.
  4. Press Alt+W for a factory reset.
  5. Press the Home and Back keys again for about 25 seconds.
http://www.resetcellphone.com/solution/HTC/g1
Jul 27, 2011 • HTC G1
My g1 wont pass the android screen it turns off automatically and its been charging for 6 hours and it only shows me the red led please help!! Thanks
Try swapping out the battery with a fully charged battery. However, this is most likely a hardware issue with the battery or the phone itself. Try switching the battery first, but if it doesn't work, it will have to be serviced by a technician.
1helpful
My g1 wont turn on when i try to hit the power button the top light turns blue and when i do the reset it dose the same thing
Is the battery charged? Is the charging LED showing up as normal when you connect the charger? Try charging the battery for a few hours and then try to reset the device?
May 04, 2010 • HTC G1
1helpful
2answers
BLACK SCREEN · I TRIED TO RESTART MY PHONE AND NOW THE SCREEN IS ON BUT STAYS BLACK
I feel your pain. My g1 droped, the screen cracked, now 3 weeks later my screen turns black. Not even turning it off or removing the battery for hours changes this. However, i found if you wiggle the screen just right sometimes you can get your screen back... for a little bit.
Oct 17, 2009 • HTC G1
My g1 has a blank white screen screen locked
I dropped my G1, picked it up and it was fine went home a few hours later starting going through my apps it started running weird then it shut off...I took the battery out and put it back in when i did that it vibrated telling me there was life in the battery but the screen stayed blank no G1 intro no android nothing...then screen is not black but a grayish white depending the angle you hold the phone at. I called my carrier we did the reset nothing happened its still stuck at the blank screen? Any help with this?
1helpful
Screen wont turn on
You are going to have to ty a hard reset. Don't worry about things being deleted from the phone, as your phone auto syncs with Gmail when you enter your account info again.
To hard reset...turn the phone on while holding home and back. Follow on screen prompt.
If that doesn't work try..
Hold home and power buttons
once phone is on, open keyboard and hold alt first + w
Feb 27, 2009 • HTC G1
6helpful
3answers
Speaker on g1 phone stopped working
Well first of, there is your warranty, but if your phone breaks after expirations, there is both an T-Mobile G1 Repair Guide and a third party T-Mobile G1 Repair Service, so there is no need to worry.
Feb 02, 2009 • HTC G1
Top HTC Computers & Internet Experts
Paul Carew
john h
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
