check your vent by removing the vent from the back of the dryer run a normal load in the dryer and if it runs normal you have a crushed vent hose or it is plugged somewhere
I would imagine your vent duct needs cleaning. We recently had the same problem and a duct cleaning kit from Lowes (about $40) took us from what felt like 'reasonable' airflow outside to "oh-my-gosh, what a difference!!", and left an astonishing pile of nasty, damp lint on the ground out there...
There's a good chance the same treatment would do the same for you. Hope it helps!
The main area that you have to clean is the pipe leading from the back of your dryer to outdoors. Pull your dryer away from the wall. Unplug it. Unfasten the vent pipe. Now look into the back of the dryer exhaust and remove any lint you see there then look into the vent pipe and remove any lint. Finally go outdoors and remove any lint you see in the pipe or the pipe grill/cover.
Could be 2 things... either your heat source is out of repair or your vent is blocked. Since you say it only gets warm I'll assume the problem is with the gas coils inside the unit. These parts are replaceable
Have you tried cleaning the actual inside of the drier? When you use drier sheets the wax on the sheets melts onto your clothes and makes them soft, but the wax often gets stuck in the holes of the drier making it incapable of drying the clothes in one load. Try scrubbing the inside of your drier with some hot water.
how long is dryer vent run ? does it go up or out to the side ? Sounds like the dryer vent is clogged. A long run on your vent will also cause this problem with a small amount of lint. Try cleaning out your lint screen on the dryer vent they can get pretty caked up with lint. If you have a long dryer vent run post back the length and direction and I will get you the maximum length for your specific run. You may need a booster fan if it is excessively long or straight up as through the roof.
first, check your exhaust, you have to make sure there is no buildup at all inside it. this is the most common problem to cause this. if lint gets backed up, there is a sensor that shuts down the heating element after only a few seconds. hope this helps
the vent that takes the air from the dryer out of the house is clogged. not the part right behind the dryer but from where it goes into the wall to where it leaves the house needs to be cleaned. when the air cant leave the dryer at normal speed it takes for ever to dry a load of clothes
