Go into you fax options just look for conformation send or confirmation on fax error you sould be able to find those options in the general fax setup.
How do i get my fax to give me a confirmation
Needing to retrieve a fax confirmation sheet/ first page sent Feb 2010..Is it possible to retrieve? if so..pls provide the steps..Thanks!
SOURCE: Printed confirmation on faxes sent form HP Laser Jet Fax M1522nf
To get confirmation page do this:
1. On the control panel, press Setup ( ).
2. Use the arrow buttons to select Reports, and then press OK.
3. Use the arrow buttons to select Fax Reports, and then press OK.
4. Use the arrow buttons to select Fax Confirmation, and then press OK.
5. Use the arrow buttons to select the option for when you want the fax error reports to be printed.
6. Press OK to save the selection.
To iclude first page with report:
4. Use the arrow buttons to select Include 1st page, and then press OK.
5. Use the arrow buttons to select On, and then press OK to confirm the selection.
SOURCE: Photosmart c309a fax confirmation?
To enable fax confirmation via the device control panel
1. Press Setup.
2. Select Print Report, and then Fax Confirmation.
3. Select one of the following: On Fax Send, On Fax Receive, Send &
Receive
4. then press OK
SOURCE: How do I print a confirmation page for this fax
1. First You need to press the additional functions button on the front.
2. Select Report Settings button
3. Select Printer button under the Print List menu
4. Press either PCL button or PS button to print the appropriate config page.
5. Press Configuration Page button
6. Select Yes button to confirm printing of config page.
