I have installed/uninstalled/installed s/w. Plugged into the same USB port as previous printer. The install seems successful but test page wont print - when I click on the printer icon, it say "communication error" and Check all connections and make sure all devices are on. If the power was turned off during printing, cancel the print job. If the error does not clear, see your printer documentation. The documentation says to uninstall. Didn't help. The test page at the printer works ok, and if I try to copy it prints ok too. The power light is slow flashing and I'm not sure if that is normal or not. I presume it is because it copies ok
SOURCE: Zebra LP 2824 Comm port problem
I believe if you hold the button down that has the green ring around it and power it back on it resets the printer to the factory defaults.
SOURCE: I am trying to uninstall my Lexmark X4270, but an
you will need to go into your printers folder find the ip address of the device ensure it doesnt have any jobs in que, uncheck the ip address and change to LPT1 then go into file at the top of your printer folder server properties Ports, find the ip address of the printer and delete it then hit the drives tab at the top of the server properties page and delete the driver for the printer also, this should resolve your issues.
if this answers your query please rate me accordingly.
thanks
SOURCE: I have the lexmark x1270. When a prit job is
Check the bottom right side of the PC screen.
If you see the printer icon there, double click it. That opens the print queue.
Highlight the print job that is causing the failure and delete it.
Don
SOURCE: Communication Error
Check and install the latest drives. (For mac) http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=94511&prodoid=63073901&BV_SessionID=%40%40%40%400218894292.1275072535%40%40%40%40&BV_EngineID=cceiadekidfmejlcgemcfjgdfljdfon.0&cookies=no&infoType=Downloads&platform=Macintosh&x=12&y=8
