Question about Dishwashers
Maytag Quiet Series dishwasher won't start
I have a maytag quiet series 200 dishwasher. It won't start; there are no lights on. If I hit the cycle select button the hi temp wash light and the heated dry light comes on but nothing else happens.
  • 24 Answers
Sounds like you have a bad Control Board
http://www.partstore.com/Part/Maytag/Maytag/MDB6600AWW/Maytag/Maytag/99003160/New.aspx
But with the price it cost, you might be better off buying a new dishwasher, preferably a different brand, cause that washer has some bad reviews
Posted on Oct 12, 2009
  • PROSPERO GALIDO
    PROSPERO GALIDO May 06, 2013
    WHAT IS THE BRAND THAT YOU CAN RECOMMEND WITH SAME WIDTH X DEPTH X HEIGHT AS THE QUIET SERIES 200?
    New Friend:
I had the same problem, and you can usually reset the board. The panel is probably going bad, but this solution will often work as long as you only want the basic, normal cycle. I have a Legacy Series Maytag Quietseries 200, and you can reset the panel by pushing and holding the "start" button until the lights flash and the cycle begins. Just realize that once it resets, you will have to let it run the full cycle.
Posted on Nov 18, 2011
I DO NOT HAVE A SOLUTION. A HANDYMAN CAME AND SAID IT COULD BE THE MOTOR THAT STOPPED WORKING. HE TRIED TO RACK THE MOTOR BUT WON'T MOVE.
WHAT IS THE EQUIVALENT IN SIZE OF THE QUIET SERIES 200? i MAY NEED TO REPLACE THE WHOLE UNIT. THE DIMENSION IS 23.5" W X 23" DEPTH X 30" HIGH.
Posted on May 06, 2013
I had a similar problem. I'd get no lights at all when pressing buttons, only an occasional "delay" light would go on but I couldn't get it to run. This would happen on and off for months. I took the thing apart, noticed the ribbon between the buttons and circuiyboard looked like it had a rusty or burnt spot in it. I put everything back together and the thing worked. Maybe something was loose somewhere.
Posted on Aug 16, 2012
SOURCE:
Maytag Quiet series broken?
Check the door switch.
May 03, 2013 | Dishwashers
1.5 year old Maytag Legacy Series Quiet Series 300 Lock Light on
Hold down the heated-dry button for 3 seconds and the light will clear.
Nov 07, 2009 | Maytag 24 in. MDB9750AW Dishwasher
Maytag Quiet Series 300 Dishwasher will not turn off after it com
MY DISHWASHER KEEPS RUNNING, IT IS A WHIRLPOOL GOLD QUIET PARTNER IV
Apr 05, 2009 | Dishwashers
Maytag quiet series 300 leaks from front
check the float switch on the righthand side on the bottom in the corner it should click and move freely
Dec 16, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
Maytag Quiet Series 300. The lights flash in sequence starting from the outside traveling inward. The timer counts backwards from 50 to 1. Then the sequence starts over. and continues over and over. I'm able to clear it when the time reaches 1 or 2. It stays off for a while (3-4 hours) then starts over. I can not clear the countdown until it reaches 1 or 2. After I clear it the dishwasher will work, but until then, no way. This happens with the door open or closed.
Sep 15, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
I have a maytag quiet series 300. When it is done with any of the cycles in leaves about 1-2 inches of water in the bottom of the dishwasher. I can manually hit the start button twice and it will go...
Hi jeffwirch,
I'm Harvey the Master Plumber.
Your problem is: You have a maytag quiet series 300. When it is done with any of the cycles in leaves about 1-2 inches of water in the bottom of the dishwasher. You can manually hit the start button twice and it will go through a 2 minute cycle and pump out the water. You have cleaned the filter inside the dishwasher where it drains and have checked the hose to the disposal and it pumps out fine. It just doen't pump itself at the end of the cycle.
It sounds like a bad control board. It's in the top of the door panel. I don't recomend this repair to the average homeowner. You might consider the Repair Directory to find a repairman.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 13, 2008 | Maytag Dishwashers
Maytag quiet series model #:MDBH950AWB
The dishwasher lights are all blinking, it starts randomly, like one in every 50 times you press the buttons. I have unplugged it to reset several times. Nothing is working. I'm looking for a solution to blinking lights and it not starting. is there any other way to reset the controls????
Jan 13, 2008 | Maytag 24 in. MDBH950AWS Built-in...
Dishwashers Logo
4,742 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
