My wife's kitchenaid classic 250 watt mixer was knocked off of the counter now it vibrates out the pin that holds the mixer to the stand and the mixer wobbles badly on the base. How do I fix?
It sounds like your mixer likes to take a beating, ive never dropped one and for good reason, they weigh quite a bit. first check to see if all the rubber legs on the bottom are still there. if they are the only possible solution to fix it after being bent or warped is to either re-shape the part using a tool strong enough to do the job, or to replace the parts needed. the hinge pin part number is 16910. is the base is bent the part number is 240151-1. If the lower portion of the mixer itself is bent or warped this is a serious problem and will require you to dissassemble the entire unit. part number for the lower gearcase is 240350-4 Please not that all the parts list are white in colour. hope this helps.
Thanks
i off the back piece covering the motor and dusted it then put the cover back on. now it wont start
