How do i adjust the mower deck on my murray riding mower, it sits too low to the ground
Park the tractor on a firm, level surface. . .
At the lower end of the lift/lower travel slot, there should be a plastic cover which you pop up so that your blade lift handle goes all the way down (it should say something about blade level on there somewhere. . . . .
After you have the handle in this position, look at the front lift arms of the mower deck and find the 2 large wing nuts, one on each side. . . . .
Loosen these while the deck is down and then retighten them Your deck is now level and will lift to its highest recommended position when you raise the lever
If you want perinent assistance and/or a definitive answer to your lawn mower problem YOU MUST INCLUDE A MODEL NUMBER AND BRAND NAME so that we know what to tell you!
