Hw to change air filte rin 2007 Honda Odyssey
The problem with other web instructions is little guidance on how exactly to remove the glove box. First, the little cover over the control am needs to be pulled off (down towards you). Either fingers or a screwdriver.
Next, trickiest part is removing the retaining tabs. See instructions here:
http://techinfo.honda.com/rjanisis/pubs/AI/AII38194.pdf
Basicaly, there is no way to ge behind the glove box to compress the release tabs. So insert a scredrver into the plastic tab cover from the insider of the glove box and just pull towards you until it pops out. When reinserting just place back (with the retainer cylinders poking back through the opening from inside the glove box) and press back in until it snaps.
On the 07 Ody, once you ave the control arm released and the two retaining tabs removed, the glove box should fold down completely. Then just press towards each other the two black end tabls holding the ac filter compartment door. Took me 30 min to figure out, hopefully with this should take you 5 ...
