Water leaking out the bottom of the disposal. What to do ?
Check WHERE the water is coming from... tie paper towels around the fittings... at the top of the elbow that comes out of the side of the disposal and points down, just below the compression nut where the vertical part of the elbow enters the P-Trap, below the nut on the other side of the P-Trap, below the nut on the bottom of the elbow where the vertical part of the P-Trap goes horizontal. DRY off the bottom of the cabinet and put a dry paper towel down...
NOW, run the water, get a good flashlight and see exactly where the water is coming from (the paper towels tied around the pipes will help you see which compression fitting is leaking) if the water is not coming from one of the joints, and is coming from the actual disposer housing, that housing may be cracked and need to be replaced. Otherwise, if you can find the compression fitting that is loose and leaking, tighten it. If that doesn't work, you may need to replace the compression ring (plastic washer) which you can buy at any HW store.
Here is a tip that I wrote about how and where a garbage disposal will leak and what can be done to fix it.
Garbage Disposal Leak from bottom of motor
heatman101
c
heatman101
t
heatman101
p
