Change channel, lose picture. power off/on, picture appears
2 years old, picture still fantastic. When changing channels or going from Direct DVR listing, screen goes black and changed channel/program picture does not come on. Sound changes to correct program/channel. Have to turn off TV power and turn back on to make picture appear. Then it is perfect again, until another channel/recorded program is selected. Then same thing. Always comes up, picture always perfect. What's going on ?
Hello Friend, I am Nitin Khatri from India. 2 reason for this problem. 1. HDD Status OK but not showing recording due to Date changed to old year,month,day, please check camera date and search recording. 2. HDD Status fail, so you need to do following things:- Your CCTV DVR HDD is not working or got stuck while recording footage, now you need to reset your HDD. Note:- As you mentioned you replace Computer HDD into DVR, it means your have installed Normal HDD in CCTV DVR which is a bad idea, your CCTV technician should inform you that time when he installed that normal HDD in DVR. CCTV DVR HDD called Surveillance HDD which RPM rate is higher and can work well for recording footage buy a Western Digital Surveillance HDD and Install into your CCTV DVR for future safety.
Hello, This will require you opening the back cover of the television to test some component with the use of an ohmmeter. This may be a slight drift - like someone is messing with the fine tuning or such a substantial change in tuning frequency that the channels go by as though you are surfing.
Possible causes depend on tuner type:
1. Quartz tuner (10 button direct access digital synthesizer) - For a slight drift, a component is probably changing value, possibly the crystal in the reference oscillator. For gross changes - flipping through channels - it is more likely to be a digital control problem - the microcontroller is misdirecting the synthesizer to change frequency.
2. Varactor tuner (buttons but not direct channel access) - If only a single pushbutton selection is the problem, the the varactor tuning diode for that button is probably changing capacitance. If all channels in a band (Vl, Vh, U) are having a problem, it is more likely to be a drifting D/A or faulty AFT (Automatic Fine Tuning) circuit or power supply.
3. Turret or switch tuner (Knobs) - A component like a capacitor is changing value.
You will have to get in there with a heat gun or cold spray and track it down the old fashioned way. At least, the problem is almost certainly localized to the tuner box (and possibly the controller if applicable).
As noted, gradual slight changes in tuning are likely due to frequency determining components drifting.
Uncontrolled channel surfing is probably a logic problem. For the quartz tuner, this could still be marginal connections causing the microprocessor to misdirect the synthesizer to change channels.
For the latter case, particularly, the cause may still be bad connections resulting in loss of channel memory and/or erratic behavior. Take care...
I have the same set, same problem with one of my MOTOROLA boxes, but not with another. I have a SONY TV that works fine with this new MOTO box, but the new VIZIO does not. The audio is coming through the HDMI cable just fine, and the fact that it works when you cycle power on your TV means it's the SYNC between the TV and the BOX. I have the identical problem and am taking back the MOTO box for another one. I spoke to VIZIO for about 45 minutes trying different things. They think it's the MOTOROLA box, COX (my cable company) thinks it's this particular box, who knows.
Hello, it sounds like your inverter board is goin out on the set, when you change channels if you notice on almost any TV the screen goes dark and the new channel appears, it sounds like you are not getting enough power out of the inverter board to power up the backlight enough to come on. This is why the sound remains because everything else works fine and the sound is connected to the main board.
Make sure u have signal on both tuners on the DVR ( check it in your set-up screen). both tuners should have the same siganl strength. Directv's DVRs, if installed correctly, give u the option of recording one channel and watch another, or recording 2 seperate channels( 2 tuners). If you are recording 2 seperate shows and u change the channel one of your recordings will cancel .
Have questions about your upgrade? We've got the answers.
What do I need to do to receive my upgrade?
Nothing! Just make sure your DIRECTV HD DVR is continuously connected to your land-based phone line and you will receive the upgrade automatically.
When will I receive my upgrade?
The 6.3 software upgrade will roll out over a period of several weeks. Customers with more than one DIRECTV HD DVR may receive their upgrades at different times for each receiver. We appreciate your patience while we deliver these new and improved features to eligible DIRECTV HD DVR customers nationwide.
Are all DIRECTV DVRs receiving this upgrade?
No. DIRECTV DVR models SONY SAT-T60, PHILIPS DSR6000R and HUGHES GXCEBOT will not receive the 6.3 software upgrade. Other models received a similar upgrade, 6.2, in the past.
I have a DIRECTV R10 DVR with 6.1 software. Will I receive this upgrade?
No. The 6.1 software on the DIRECTV R10 DVR already includes the 6.2 features such as folders and faster menu scrolling.
Will any of my DVR settings be changed as a result of the upgrade?
Yes, some of your settings or preferences will be changed back to the factory default settings as a result of the upgrade. These include: "Favorite Channels," "Channels You Receive," "Spending Limits," "Clear Channel Banner Quickly" and "Dolby Digital" recording and output.
To change Channel Banners, Channels You Receive and Favorite Channels preferences:
1. Select "Messages and Setup"
2. Select "Settings"
3. Select "Channels"
To change Spending Limits:
3. Select "Parental Control"
To change Dolby Digital Settings:
3. Select "Audio"
4. Select "Dolby Digital" and "Digital Output"
Will I be charged for this upgrade?
No. We're upgrading your DIRECTV HD DVR as part of your normal DIRECTV® DVR with TiVo® service at no additional cost.
What happens if I don't have my phone line plugged into my DIRECTV DVR?
You will not be able to receive the upgrade if your DIRECTV DVR is not connected to your phone line. To install the upgrade, your receiver must successfully make a call to our servers.
How will I know when I have received my upgrade?
You'll receive an on-screen message the first time you visit DIRECTV Central after your upgrade is complete. It will also appear in your Messages section. You can also check your System Information screen to find out which software version you currently have.
Will the download delete any of my currently saved programs?
No. All of your saved programs will still be there for your enjoyment after the installation.
Once your upgrade is complete...
How do I activate the Grouping (folders) option?
1. Go to your Now Playing List.
2. Press Enter on your remote control.
3. Change groups to ON.
SHORTCUT HINT: While viewing your Now Playing List, press number 2 on your remote control and your Now Playing List will change from the GROUPS view to show each individual recording. Press 2 again and it will switch back to the GROUPS option.
How do I sort alphabetically instead of by date recorded?
3. Change sorting option to Alphabetical.
SHORTCUT HINT: While viewing your Now Playing List, press number 1 on your remote control and your Now Playing List will change from alphabetical to date sort. Press 1 again and it will switch back to alphabetical sort.
Some settings will restore to factory defaults when the new software is download
