Oreck XL2000 Bagged Upright Vacuum Logo
Posted on Oct 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Oreck upright hard to push - Oreck XL2000 Bagged Upright Vacuum
Anonymous
Level 2:
Sergeant:
  • Expert 206 Answers
  • Posted on Oct 13, 2009
Anonymous
Expert
Level 2:
Sergeant:
Answers
206
Questions
Helped
106331
Points
597
If hard to push, only a few things to check:
(1) Rear wheels will get hair or thread wrapped around axles, dust, etc. and be hard to turn. Make sure each wheel turns easily.
(2) Small wheels on newer models (since about 1997-98) toward front are worn, missing or have same problem as item 1.
(3) Brush roll not turning. The brush roll actually helps pull this unit along the floor, as it rotates in the "forward" direction. If the belt broke, and you do not realize it, it may suddenly seem harder to push.
Why is my oreck xl 21 hard to push on carpet?
sometimes the little rubber wheels in front wear out of round and bind. Try those first (if they're the tiny ones you must buy a pack of 20 from oreck directly) and Orecks are known for being hard to push when bag begins to fill up.
I’m happy to assist further over the phone at https://www.6ya.com/expert/howard_977676954994c5b2
Vacuum hard to move on carpet
The key to getting an Oreck to move or push is to use as low and angle of the handle as possible. The more upright the handle, the harder the machine is to push (move). The lower the angle or the closer the handle is to the carpet, the easier it is to move (push). Use a straight stiff arm that is pointed down and move your arm at the shoulder with a near locked elbow.
Orek very hard to push
The key to pushing an Oreck is to use as low an angle of the handle as is possible. The more upright the handle, the harder it is to push. The closer to the floor that the handle is, the easier the machine is to push.
Adjust height for plush carpet
The best solution is to change your method of trying to push the vacuum. The more upright the handle is on an Oreck, the harder it will be to push. The lower the angle (the closer the handle is to the carpet) the easier it will be to push. There will be a huge difference. Use a straight stiff arm that is pointed directly down towards the carpet. Use your shoulder and have a near locked elbow. The vacuum will now push easily.
Hard to push
When mine did that, I bought a new roller and it runs like new now.
Good luck
2answers
1helpful
Oreck XL hard to push
yes. it might be broken. you will need to remove the 5 screw on the bottom and see if the belt is burned. it more that likly is.
4helpful
While vacuuming it's unusually hard to push.
I see your post is from May. I just joined Fixya this month so, id you're still looking for a solution, I would saythe belt broken or is so stretched the roller isn't spinning. Here is an link to an online guide with illustrations for changing belt. Also check the roller brushes for wear and change if necessary. Hope this helps.
http://www.info-vacuum-cleaner.com/oreck-vac-belt.php
Top Oreck Vacuums Experts
john h
hsapiens
Level 1 Expert
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
