Sanyo DS31520 31" TV Logo
Posted on Dec 26, 2007
My Sanyo TV
I have lost the remote and can't switch it to the game mode. Can Anyone Help Me???
Sanyo Model DS25320
23"
  • thil4thil Mar 19, 2008
    I have the same problem .I bought a universal remote and programmed it but except the gaming mode function(switch the input to Tv from cable to AV port) everythign else is working in the universal remote. I am using GE 94906-D 2342 universal remote
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 08, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
435
Points
I just had the same problem. Which has just been resolved. I bought a sanyo remote for $5.99 from Sanyo. It was shipped and I received it in 2 days. Look up the site at [email protected]
A
Anonymous
Anonymous
Level 1:
  • Posted on Mar 03, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
435
Points
0
Yes, go to remotes.com for a replacement. Around $40.00
2helpful
2answers
My tv is stuck on the blue screen .
Go push menu button on the front of tv or the right side.Pick the video out,or tv.Or buy a remote.Website 1-800-Remotes factory Original.For the original remote.
1helpful
RCA remote codes lost
Codes For Model RCR311B
Code 1004 for Sanyo TV Code 1048 for Sanyo TV Code 1049 for Sanyo TV Code 1073 for Sanyo TV Code 1080 for Sanyo TV Code 1162 for Sanyo TV Code 1169 for Sanyo TV Code 1180 for Sanyo TV
Codes found here: http://remotefinder.rca.com/default.aspx?site=rca
RCR311B manual (PDF): http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/rca/rcr311-manual.zip&area=other
4helpful
3answers
1helpful
TV stuck on Video
I had this problem, I replaced the remote and it works now
Old Sylvania model #6420FB lost remote how to switch to av mode
Unless the TV has a front-panel menu button and allows you to switch modes from there, you are out of luck. There are two possibilities. One is to try another replacement remote. If you get a universal remote made by the TV manufacturer (Magnavox), it may have buttons that will work. The other option is to purchase an RF converter, which will cost around $15. This will take the video/audio signals from the game and convert it to a channel 3 or 4 signal you can then tune in on the TV. The picture won't be quite as bright and clear as with direct AV input, but it will do the trick.
Lost Remote
My best guess is go to Partstore.com. They have tons of replacement remotes. Good luck.
2answers
Need codes for a Sanyo TV
0049, 0097, 0110, 0004, 0268, 0012, 0108, 0180
3answers
Sanyo lost remote
I had the same problem. Just got a DVD player and hooked it up and nothing. I got the Sanyo TV from a relative. Anyway channel 3,4 not work and when I go 00 still nothing. Then I pressed Input on the remote and a blue screen popped up. Turn on the dvd and now it works with channel 4. So I think any remote will work just put the tv to channel 4 and press input on the remote.
11helpful
3answers
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
