Konica Minolta bizhub 350 All-In-One Laser Printer Logo
Posted on Oct 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need to reset admin code - Konica Minolta bizhub 350 All-In-One Laser Printer
Anonymous
Level 2:
Champion:
  • Expert 214 Answers
  • Posted on Oct 14, 2009
Anonymous
Expert
Level 2:
Champion:
Answers
214
Questions
0
Helped
192279
Points
268
Hello
go to the service menu (utility counter - details - stop 0 0 stop 0 1- in service menud stop 0 C
Mp252 Audio Codes problem
maybe admin/1234 or you did not reset it, hold the reset button longer
Need to reset admin code for minolta di3010f
Press the utility button, then touch screen, meter count, then stop00 stop 01. Then admin input to change the password default is 00000000.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
4helpful
2answers
How do I log into my router config if I don't know the password? I've tried pushing the button on the back to reset but that didn't work
Hi vmontour,
To Factory reset your router you need to locate the Reset Button at the back of the router. The Reset Button is the small hole at the back and you need a Pen or a Paperclip to press it. Press and hold the reset button for 15-30 seconds. Make sure that the router is on when you reset it.
To access the router page just open a browser then type 192.168.0.1. the username is admin and the password is blank.
Rate me if this will help you so that i can help other people.
Thanks for using Fixya.
My husband was home when new router was installed, he did not get the key code. When I try to access 192.168.1.1 my computer does a google search for it, or I get there and the password admin and user...
you need to reset the router usually you need to hold down the reset button for about 30 seconds to fully reset it, also google the make and model of the router and you should be able to get some detailed instructions but a full reset will allow you to enter the routers setup and enter your own password and properly configure it's security features for your needs, best of luck!
An employee just left I I have inherited their phone and extension. How do I access the voicemail system, to set up my voice mail on a partner 18 Avaya? Thanks!
You need the admin password to reset the VM user mailbox. This is the Vm admin pass code, If this has been changed you are out of luck. I can reset the pass code for 25.00 remotely,
Need to reset admin code for konica minolta c-350
Hello
press utility/counter - then under the counter "details" - stop 0 0 stop 01 - now you are in service mode, - stop 0 C, and there shold be admin pwd
1helpful
2answers
Toshiba Default code not working
Need to login to Admin mailbox 999 or 9999 (3 digit exts or 4 digit exts?) need to know admin password? once in follow prompts to edit maiboxes to reset password to default. Default is 997 and ext number,but the tech that setup your phone system could of change the default code(997).What Toshiba system do you have?
3answers
Konica Minolta CF3102
If it is the Admin password that is needed to be reset you CANNOT! You need to find out what it is to change it.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
