SOURCE: Hard reset of KX-TCD580 Base
Go to this link; http://panasonic.co.uk/customer-Support/download-centre.asp and input "KXTCD580" in the search box - after a few disclaimer screens you get to the manual for your phone. page 29 details reset for the handset Page 32 details base unit reset Page 48/49 details cancelling handsets to the base Hope this helps, please post again if you are still having problems with your phone :)
SOURCE: no link to base Panasonic KX-TG2357
are you running a wireless router? try unpluging router to test phone.
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
SOURCE: Panasonic KX-TG2740 Cordless Phone - Can I reset handset registration
press function button on handset, scroll to initial setting, select by pressing right arrow, scroll to registration, select, select hs registration, follow directions on handset display, pressing mute on "new" base station, and ok on handset(plugged in). If you like, you can unregister with the "old" base unit first.
SOURCE: KX-TG6052 two handsets. Can't get Talking-Caller ID to turn off!
to turn the talking caller id off go to the menu press 0 then * then 4, then press 0 again to select off.
to turn the ringer on the handset back on, go to the menu, prees 1, 1, then press 1 for a low ringer, 2 for medium and 3 for high.
SOURCE: Handset voice very low and LCD display is blank
My 1740 handset volume was also low. As a shot in the dark I changed the speaker and it fixed the problem. I got a new speaker from www.panasonic.com .
