Cleaning your Tub
There are several options for cleaning the piping on a jetted bathtub.
The reason you have a residue on the bathtub surface when you are done bathing is because there is bacteria built up in the plumbing of the jetted tub. In order to remove that and reduce the amount of "yucky stuff" coming into the tub when using it, we recommend a regular usage of a jet cleaning product about once every couple of months
Here is a link to the cleaning products I can find right now. There may be other out there that I am not aware of but I do know these products work well in all jetted bathtubs.
Cleaning your Tub
The problem you are experiencing is common to many jetted bathtubs.It is a result of dried bathing water in the tub. There are a couple of solutions to resolve this ongoing problem.
Use your tub more frequently as the water will not have time to fester in the pipes.
Use a cleaning solution made for cleaning the pipes on jetted bathtubs once every three months.
You find Cleaning and Maintenance Products for jetted tubs at the following website. US Parts Center
depends on the computer and TV. new stuff will have hdmi ports, older stuff has svideo which also requires and audio lead 3.5mm headphone Jack to 2rca. hope that helps
You need to get some jacuzzi cleaner solution or hot tub jet cleaner solution fill the tub with the solution and follow directions to clean them out needs to be done every couple months IF THIS HELPED PLEASE VOTE FOR ME
Try a different browser, like firefox, see if you have the same issue. also ensure that you have the updates from www.java.com and update Flahs and Shockwave from www.adobe.com
