When using cable input video is good but sound has a fuzzy static sound that is almost just as loud as the tv program sounds.the rca plugs work fine tho!?!any ideas???
Your TVs tuner tuned a little off frequency. It could be as simple as having cable box on where you have good picture but fuzzy sound, use the TVs remote to change the channel and then change it back to proper channel. If that doesn't fix you may have wrong tuning type selected in channel set up menu.
Thanks for the quick reply!!!
My cable box doesn't work so i have the cable hooked into the cable input.When it did i had the same problem.Anything hooked through cable input makes this annoying fuzzy static sound!(on any tuning setting) My converter box does the same thing when hooked to the cable input. so...you think the tv tuner is off frequency? how is this fixed? do i have to take it into a shop?
thanks! Nelson
thanks! Nelson
thanks! Nelson
thanks! Nelson
