You need a standard SD digital memory card (not the newer HC high capacity cards as Magellan does not guarantee compatibility although I did get one to work that was a micro SD card with the full SD adapter). You will need to put your mp3 music files from your PC onto the SD card just as you would your mp3 player; insert the SD card into an SD slot on your computer, laptop or USB adapter and copy the files to the card. After files are saved, put the card into the slot on the right side of the Maestro and then refer to the User Manual (http://www.magellangps.com/support/product.asp) page 64 to see how to play the music. You can play through radio speakers or by using headphones/ear buds with a USB connector.
