Motorola Mobility Karma QA1 Cell Phone Logo
Posted on Oct 11, 2009
My moterolla karma will not turn on at first it turned a redish tint and then shut off but now it wont go back on.
How do I get rid of the redish tint on all images in low light using this flash?
I could be wrong, but I would switch to the manual mode and turn off the automatic features since the red light is actually an inferred sensor used to determine when enough light has fallen on the subject and tell the flash to terminate. By going to manual, you remove the need for the circuitry to tell the detector to turn on.
1helpful
MY MOTOROLA KARMA WONT CHARGE OR TURN ON
Hi, You may try to use to use a different charger that will fit in to your phone or a different battery. It might be a failure on the battery.
3answers
Mitsubishi 50inch TV Turns off right after I turn it on
tv is in shut down.could be several things.call a repairman.
Redish tint on pictures
your printhead needs to be replaced because, most likely, the jets that shoot the ink got blocked because of the remaining ink from your last printing session.
Just go ahead and go to kodak.com/go/itg , follow the troubleshooting and have your printhead replaced, or call their support center on 1 800 421 6699, and have them help you out.
1helpful
Monitor turns off
If the picture is Reddish either at top or bottom It could be the backlight failing.If you are technically able you maybe able to Replace the CCFL backlight.
Samir
RIO KARMA MP3 PLAYER
Hi are you still trying to get music off your rio karma. E-mail me at [email protected] if still needed
Tv turns off, volume adjusts incrementally then shuts off, screen is tinted blue
there is a defecton the small signal panel. most of the time caused by power surge..john
1helpful
6answers
Rio Karma freezing on startup. wont connect to computer.
WoW! thanks a million, I had tried everything to fix my wifes RIO and nothing worked! hitting it actually solved the problem!!!!
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
