I also lost the manual for my GE JC024 Universal Remote. I remembered though that you just hold in the button for the device you want to program and the "SETUP" button at the same time for about 5 seconds until the red light on the remote flashes and stays lit. then let go of the buttons.Then you basically just press and let go of the on/off button, pausing for a second or two in between presses until your device turns off. then you have to press the "ENTER" button and it'll store the code for that device. This method just cycles thru all of the possible codes for that device. sometimes you get the wrong code and the remote wont completely work. like hitting the volume button makes the tv mute for example. just repeat the steps until the device turns off again and eventually you should be able to get it. hope this helps.
Here's how to do it manually. Press and hold the setup button. Select the device you want to program.and push that buton. Then press power until it turns off, or on, doesn't ,matter which.When it reacts you have it, then press the STOP button ( the box above the red button on the bottom and to the right). Done.
your awesome no other way helped
thanks your awesome no other way worked
yay! this worked for me thanks so much!!
SOURCE: need ge universal tv codes
you can set up any like this
1. turn on what ever you want set up
2. press and hold set up tell light blinks or stays lit
3. push what you are trying to set up t.v. or dvd ect.
4. push power on/off tell it turns off
5. push enter when it turns off
Thank you for useing fixya please rate me
SOURCE: I have lost my manual
Try
0049 0097 0110 0004 0268 0012 0108 0180 for your Sanyo.
You can download a manual from
http://www.jascoproducts.com/support/manual-downloads/index.asp
Let me know if you have any other questions. Thanks.
Please rate this solution. Thanks.
how do you reprogram a ge jc024 remote for my panasonic tv
