Oregon Scientific Oregon Chainsaw chain for Stihl Chainsaw 20" Bar Length 72 Drive links 3/8 Standard 0.05 Gauge Chiesel Chain Logo
Posted on Oct 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Stihl ms290 chain runs constantly even when idling and when u put the chain brake on it kills the saw
Anonymous
Level 2:
Sniper:
  • Expert 61 Answers
  • Posted on Oct 12, 2009
Anonymous
Expert
Level 2:
Sniper:
Answers
61
Questions
0
Helped
97353
Points
148
Mindreader was correct to sugest the clutch. also check the needle bearing on the clutch casing where it runs on the crank shaft. the sprocket should be able to turn without turning the crank shaft. If it is tight, change the bearing
Jim DuBreck
Level 3:
  • Master 578 Answers
  • Posted on Oct 10, 2009
Jim DuBreck
Master
Level 3:
Answers
578
Questions
Helped
252830
Points
1695
The centrifical clutch is probably rusted (or has a broken spring). You can try a small amount of WD-40 inside the clutch to see it that will break it loose.
Also, be sure that the chain tension adjustment is not too tight!!
1helpful
How do I find a parts manual for a Stihl MS290 ?
I really don't want to be "that guy", but people who aren't trained STIHL mechanics or at LEAST mechanically trained, shouldn't work on higher end saws like STIHL, because people with a little bit of experience can mess something up, then blame the machine because they mess something up and start trashing the brand when it's their fault for not knowing what they're doing.
2answers
My stihl chain saw runs full out without pulling the trigger? what can i do?
carby idle adjustment or a carby kit and clean needed
carby has a high and a low rpm jets
STIHL MS 290, 310, 390
https://www.stihlusa.com/.../instructionmanuals/stihl-ms-290-310-390-owners-instructio...
Instruction Manual - improper use can cause serious or fatal injury. MS 290. Warning! ..... model. Safe use of a chainsaw involves. 1. the operator. 2. the saw.
How to change chain tensioner on stihl ms 290 farmboss chainsaw
sthil ms 290 chain saw 9-10-12 - YouTube
? 11:18
https://www.youtube.com/watch?v=-xJAcXZqeog
Sep 10, 2012 - Uploaded by skidoo849
sthil chain saw 9-10-12. ... my 2012 STIHL MS 290 FARM BOSS CHAIN SAW WITH A 16'IN BAR. - Duration: 34:11. MRJOHNDEERE3720.
How To Adjust Your STIHL Saw Chain - YouTube
? 7:21
https://www.youtube.com/watch?v=dZq7ZDBx4iA
Dec 4, 2012 - Uploaded by STIHL USA
Learn the differences in adjusting a cold chain vs.a recently used chai. ... Also learn about the STIHL Quick Chain Adjustment feature found on certain STIHL chain saw models. ... Stihl MS290 Farmboss Discussion - Duration: 5:37. ... How to Replace the Bar & Chain Oil Pump Worm Gear on a Stihl MS 029 ...
[PDF]STIHL MS 290, 310, 390
www.stihlusa.com/WebContent/.../MS290_310_390_Manual.pdf
StihlInstruction Manual - improper use can cause serious or fatal injury. MS 290. Warning! .... engineering changes and improvements ... When using a chain saw for.
Chain Tensioner Adjuster for Stihl Chainsaw MS290 MS39
Stihl ms 290
That sure is an MS290 in the picture, alright. If you have a question about it though, feel free to voice it. Or text it here if you wish. Fantastic!!
Oil not goingg to the bgar
Have you cleaned the oiling hole in the guide bar.? Scrape out the full length of the guide bar using a cleaning tool. There is an oiling hole at the back of the bar on either side which the oil flows into.
Is oil being pumped out the saw.? Remove side casing and guide bar, run the saw and check the flow.
Saw will start and run but chain wont turn
Chain brake may still be applied.
The chain brake is the front hand guard, pull it towards you to release the safety brake. Check chain tension, the chain may be too tight.
I have a ms290 starts fine idles fine but after about 15 minutes of cutting wood it loses power an dawgs out somtimes kills,
Hi goincrazy, check that your carb tubes are ok, and your exhaust filter is clean, also clean your fuel filter or get a new one. Hope that helps
Steve
MS290 have fuel spraying out of vent and fuel cap. took to dealer for repair, he replased the carberator and the vent line. no problem at the store. went to work cutting fire wood, stated doing thye same...
The engine is getting pressure someplace. It could be a cracked head.(This would mean the saw is a goner!) I would look at the dealer invoice and see what their warranty time is on their work and explain to him, that he did work that did not fix the problem! There is always the chance that he has a used chainsaw that he would be willing to trade for the money you have already spent!
2answers
I have a ms 290 farm boss with an 18" want to
Yes! So here are some links:
STIHL Ematic guide bars are engineered and manufactured to STIHL's strict quality control standards and are produced in STlHL's own factories. STIHL offers a full line of guide bars for all types of use from 10" for specialized wood carving applications with small saws through 59" for extreme felling operations. Explore our products to find the STIHL guide bar that's right for you. Locate your local STIHL dealer.
arrow_orange.gif STIHL ROLLOMATIC® ES Super arrow_orange.gif STIHL ROLLOMATIC® E Light
arrow_orange.gif STIHL ROLLOMATIC® E Standard arrow_orange.gif STIHL ROLLOMATIC® Mini
arrow_orange.gif STIHL DUROMATIC® E arrow_orange.gif Carving Guide Bar
Thumbs back!
1helpful
Stihl MS290 only runs if the gas tank vent valve is removed, then it runs. also when after cutting a full throttle upon release chain saw does not recover to an idle but dies. Have put in new carb. and new...
sounds like you have a plugged vent either in the gas cap or the vent valve of which you speak. Without the vent working properly, the engine running and drawing gas from the fuel tank causes a vaccum inside the tank making it harder for the fuel to draw to the carburator. this would cause the symptoms that you are talking about.
Replace the gas cap if it is vented or check to see if the vent valve you mention is working properly.
Good Luck
Dec 21, 2009 • Garden
Top Oregon Scientific Measuring Tools & Sensors Experts
Dave Parker
Dave Parker
Level 1 Expert
Are you an Oregon Scientific Measuring Tool and Sensor Expert? Answer questions, earn points and help others
