I have a model A-4-9K HB11-D Wolf gas stove. I need to replace the open top burner assembly. When can I find this part? When I bought the stove (1993) it was Wolf's part number 753360A. Thanks.
Pilot lights go out because the Thermocoupler is either bad or not getting hot enough. It will be a copper tube that should touch the pilot light flame. these are replaceable and usually any appliance repair supplier can get you one. Some units reuire changing out the entire gas control
The electrode (spark plug) for that burner is not telling the spark module the burner is lit and go ahead and turn off the spark. That electrode and the wiring on it need to be replaced,from that burner back to the spark module.
I hope this helps you to repair the problem with you stove, Gene
Depends what Wolf model you have, if you have model AS48KI and the flame looks really high, (it supposed look like a flower), most cases the top burners are misaligned, you can try to re align the burners by turning them around. afterward if the burners are still clicking it may be ignition problem. Have fun.
Remember to turn the control knob past the "LITE" setting once the burner fires.
If that is not the issue you have one or more defective spark switches.
Each valve has its own switch wired in series with the others.
It is possible but you have to know how, top burners will be easier to do then oven, for top burner you will needed push button switch, spark module and electrodes. I never done the oven but it is possible. Have fun.
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
Turn you burner to the Lite position:
If you hear clicking or sparking, go to Step 2.
If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
Clean the burner and electrode:
First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
Check to see if the burner works, If not, then go to Step 3.
Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
Check to see if the burner works, If not, then go to Step 4.
The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
