Often they have a chip mounted on the cartridge which monitors usage and when it determines that there is no ink remaining, it will disable the printer. Some companies sell compatible cartridges and reset the chip counter. But unless you reset the chip, even tho the cartridge is full of ink, the chip still disables the printer.
each cartridge has its unique serial number,
printer remembers him,
is absent sensor of the ink level determination in you cartridge. You can to print, but message will say to you "EMPTY CARTRIGE".
this warning function can be disconnected by you in printing driver.
If you bathe new cartridge, that level will show full.
If afterwards put(deliver) old , that he will show that empty.
Printer can have a memory about two or three last cartridges.
There is no way to reset the ink levels on this cartridge type yet. Any replacement chips on the internet are violating patent law. Once the chip tells the printer it is empty it will not print no matter how much ink is left in it. There is always a lag time between the introduction of a new cartridge type and the ability to fill it properly. For refills I would recommend Cartridge World when this cartridge type can be refilled.
1. If you have the plastic cap that covers the 9 mm. hole where you can see the sponge, then tape this cap to the cartidge with scotch tape. If not, use some duct/masking tape to cover the round hole.
2. Use the dry hypodermic needle to find the hole that will be found at the very center of the 920 label. With the needle, pierce the label.
3. Fill the hypodermic needle with 4 cc of ink.
4. Insert the needle 2-3 cm. into the hole made in step 2. Draw out 1 cc of air, then slowly force the 4 cc of ink into the sponge. Use toilet tissue to absorb any ink that might have escaped.
5. Let the catridge stand overnight (if possible) so as to allow the ink to evenly saturate the sponge. If not, insert it into your printer immediately.
Note: If you are going to refill catridges, be certain not to allow the sponge to dry completely. Thus, you might want to do step one immediately and to enclose it in a sealed sandwich bag upon removing an empty catridge from your printer even if you are not going to fill it immediately.
You cannot reset the ink level indicator for the HP 60 ink cartridge. It shouldn't matter anyway because the level is only estimated for "management purposes only" (see user manual) meaning to let you know when it's near time to order a new cartidge. I have tried cycling through 3 different cartridges to reset the ink level for the one I refilled but it didn't work. Refill and just ignore the ink level indicator. Also, it's a good idea to clean the print heads with the solvent in the refill kit before refilling to remove old ink and imrpove print quality.
You cannot reset the ink level for the HP 60 ink cartridge. Simply ignore the ink level indicator if you refill your cartridges. It is only an estimate of the ink level anyway. See pg 72 of the user manual.
The ink level indicator is only an estimate to give you an idea when it's time to buy a new cartridge. You cannot reset the ink level indicator so simply ignore it if you refill your cartridges. See pg 72 of the user manual which you can get here:
http://h10032.www1.hp.com/ctg/Manual/c01374711.pdf
