Yes, it sure can. The icemaker turns on a heater to warm the mold, allowing the ice cubes to be pushed out. If the icemaker does not finish it's cycle for any reason, the heater keeps adding more heat, which will affect the refrigerators performance. Look to see if there is anything obstructing the moving parts of the icemaker, like a package by the arm that moves, or even a screw in the mold area. If nothing can be found, an internal problem (like a gear or motor) may be the cause, but individual repair parts are not available for icemakers. The entire icemaker can be removed rather easily. (and replaced with a new one rather easily also, if neccessary)
No,what it appears to be isthe evaporator is freezing over and hindering air flow. The water under the ice maker is actually condensation because the ice maker is colder than the cabinet temp. The unit should have an automatic defrost so it appears it is cycleling through yhe defrost. Unless you call out a tech to set the defrost timer, all you can do is unplug it and defrost in its own. Was the door ajar for any period of time? not completely closed? That will also do it because of humidity. The moisture in the air will freeze. The refrigerator side cools from bleed over from the freezer.
SOURCE: Freezer and Fridge side not cooling
Sounds like your Defrost heater is burned up. It is located in the back of the freezer compartment behind the lower cover. Look at the base of the condensor. Two screws hold the heater and two wire connectors. The heater is in a glass tube. Measure continuity from one end to the other, you should see a few ohms. if it is open, your heater is definitely burned. I got a good deal on a replacement heater on Ebay. I think it was $17 including shipping. The heater being bad will cause major frost buildup in the back of the freezer and stop the Ice maker from working and damage food. Be sure to thorougly dry the freezer compartment prior to putting it back in operation. If too much moisture is present, the new heater will evaporate the moisture into the Ice dispensoer motor and solenoid that swtiches from crushed to solid ice. Hope this helps. it has nothing to do with your problem, but please Check out my website www.playstationclinic.com
SOURCE: Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
SOURCE: freezer quit then noticed fridge side not cooling
the relay on your compressor is bad go behind you refrigerator and take off the the bottom panel the relay is on the left side of your compressor usually
