The setup menu is missing the EZsetup option. How do i get it back. It was a floor model and set to "shop" , which sets the TV to Dynamic(fixed) AVmode and I can't adjust the picture values. If I manually change the AVmode to User it reverts to Dynamic after 30 minutes of no remote control use. Thanks for any help with this.
It sounds like your TV is in Shop Mode.
Shop mode is a set of picture parameters that have been optimized for a
store showroom or display floor. Shop mode does not allow you save any picture settings such as brightness or contrast. To get the TV
out of Shop Mode press and hold the Menu button on the front panel for
three seconds, the picture will blank momentarily then reappear with
"Dynamic Mode" shown on the screen. At this point the picture parameters
can be changed and saved.
If this method doesn't work for your TV there is an alternate method that might.
From the buttons on the front of the TV (not the remote): 1) Press the Volume + (increase volume) button 2) Whilst the volume button is pressed, press and keep pressed the menu button 3) Let go of the volume button and keep the menu button pressed for 5 seconds 4) After this time the screen should go blank and "Dynamic" will appear at the bottom of the screen.
from http://www.fixya.com/support/t399140-samsung_le46f8_picture_setting
hello,
Dynamic (Fixed) setting every 30 mins. Then it will go back over and over again because of store mode has selected. To remove or set to home mode you can enter initial setup. Follow the instructions from TV set . Or enter TV location from menu than choose home.
Good luck.
Go in the tv menu,right at bat u in the Picture mode go down the menu to reset push it.The Tuner board will reset it self.It will be set on the Dynantic fixed mode.And the AV mode button on the remote should able to changes back and fourth again Dynamic fix mode,Dynamic mode,Standard mode,User mode,Game mode.Not able to changes by pushing the remote button AV mode to changes,than ur Tuner board have problems,not working properly.
Your TV is in Shop Mode, its optimised for usage in a shop. People mess with the settings all day long, so when in shop mode, if you go to standby it wipes all the settings everytime.
You need to re-enable Home mode, to do this go back to the DTV menu and find the option PLUG and PLAY on the 1st with the cog icon. Enjoy!
I have the same tv and i just fixed it! mine was a display model at wal mart so it was set to reset to Dynamix (fixed) after 30 minutes of no remote activity
THE FIX: switch to TV MODE and select the EZ SETUP from the option menu when you get to the TV LOCATION option select HOME
The STORE option resets the TV after 30 mins of remote control inactivity in case someone messes up the picture settings in case someone playing with it while it was on display at the store
The set was a store demo, and the options were set so they could not be adjusted. On instruction from Samsung I pressed MENU and VOLUME buttons on the side of the set and hold for 7 seconds The display reverts to Standard from Dynamic. The Remote Options button showed Store Demo, but now shows Standard. All memory functions seem to function now. Thanks for your help. Watty2c
You need to change the option throgh the service mode.
You can not access that mode without permission from Samsung.
better to contact Samsung call center.
Shop mode is a set of picture parameters that have been optimized for a store showroom or display floor. Shop mode does not allow you save any picture settings such as brightness or contrast. To get the TV out of Shop Mode press and hold the Menu button on the front panel for three seconds, the picture will blank momentarily then reappear with “Dynamic Mode” shown on the screen. At this point the picture parameters can be changed and saved.
Yes, I tried that but it did not work.
