Hi. Just head over to http://the-checkout-tech.com/ and you'll see a link to a FREE layout designer for flat key board cash registers. They also have plenty of manuals and guides
You will find as with Dell that the motherboard etc is all custom & you cant upgrade it yourself, you have to go through Sony. I am not 100% on that but that has been the case with many branded PCs i have seen.
Can you not open the case? This usually voids the warranty but if you were intending to replace parts then it would likely be voided anyway.
You need to get the motherboard number and look it up at the manufacturer site under support you should be able to download a tech specs for that board showing the pin layout [owner manual may have it too.
if you are talking about connecting the front chassis connectors to your motherboard then you need to find out the exact model of the MB... im assuming its Intel since its a Dell.
when you hite the brakes oes your turn singal lights on the dash light up if so the bulbs are and bad o a fuse is bad get a fuse tester walmart has them ground the fuse tester theres two mteal sides on a fuse on the top hite both metal sides i one sie lights u an the other doesnt the fuse is bad
go to this site download vt5600.pdf file when downloaded sellect point 4 upgrading you computer,\system boards\mainboard layout\veriton 5600g mainboard layout.
