Canon EOS Digital Rebel XS / 1000D IS Digital Camera Logo
Posted on Oct 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Canon 100 d screen is blank seems to be frozen when trying to take a pitcure flash will pop but will get busy sign battery fully charged
Anonymous
Level 3:
  • Master 2,335 Answers
  • Posted on Apr 15, 2010
Anonymous
Master
Level 3:
Answers
2335
Questions
0
Helped
882763
Points
4663
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS / Canon EOS 1000D.
Installation of this Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update will solve these problems:
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
  1. Follow this link to download a pdf version of the firmware installation instruction guide.
  2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
Busy flash picture and 3484 code
When showing busy, most of the time the camera detected an error, but can't find out what is causing the error.
Try the normal "reset" method as follows:
Like a cold boot for a computer, the camera can be "rebooted"
follow the following steps:
Switch of the camera and remove the battery.
Remove the memory card and the lens. (if possible)
Recharge the battery. Wait till the indicator on the charger indicates the battery is fully charged.
Check all contacts, if they are clean and shiny. Contacts (from battery and memory card, only to be cleaned with a dry cloth or cotton swab(s).
Reinsert the battery, reinsert the memory card and re-attach the lens.
Then switch on the camera.
If this does not help, contact a certified Canon repair centre.
I have a cannon rebel xt and when the flash pops it it will no longer take a photo but works fine outside if flash is not needed?? Help
Does the little flash lightening bolt light up in the viewfinder to let you know the flash is fully charged? If it does, but when you push release it goes out and then comes on again in a few seconds that is the sign of a bad flash board.
Does the flash go all the way up?
Is the switch that is under the flash come all the way up (not stuck down)?
Gateway black screen
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Canon 300d flash won't fire. Pops up ok but display just reads "busy" and camera locks up. Must turn on/off to get camera working. External flash works ok.
This may sound obvious, but have you tried to make surer the battery is fully charged and then see'ing if it still does this? The reason I suggest this is that I had a similar problem and when I fully charged the battery this problem went away. I tend to keep an extra battery (fully charged) plus the charger on hand at all times.
My Canon EOS 1000D wont take photos, viewfinder flashes busy
Maybe you drop your battery and they have electronic components inside that could be spoiled, if is that the case, try to change the battery, it appeares to me that the ammount of current the battery is sending to the component is very low even thoe it seems to be fully charged that's why the camera is unable to display anything and the "busy" warning is blinking all the time, I hope you find this usefull.
My Canon power shot S2 IS does not detect the batteries
There is a battery charge level sensor in the DC/DC internal converter board.
It seems that just started to fail such board.
You can try with other brand or type of AA batteries.
If still you have the same problem, you will need to have replaced the DC/DC converter board on your camera. This means a Camera repair shop service on it.
Best regards,
Power on Problem
please make sure the batteries you are using are genuine.
Anything I can do for a flash busy error 99 message?
Could be that the battery is weak, and should be replaced as it is not holding a charge.
2helpful
2answers
Error "Err05" keeps initiating preventing flash operating
There are two versions of this problem: 1. The flash does not pop-up. 2. The flash does pop-up.
Here’s the fix to the err05 msg when the flash does pop-up. This will work on the XTi and perhaps on similar Canon cameras:
The pop-up flash has two legs. Look at the pivot point of the right leg (”right” when looking into the lens). Just in front of the pivot is a very small spring-load pin on the “roof” of the camera body.
This pin is the sensor that tells the camera the state of the flash. The pin is pushed down when the pop-up flash is closed and is suppose to quickly spring up when the flash is opened. Problem is, the pin sometimes gets dirty and drags. When it is slow to spring up … you get the err05 message.
Fix: Take a small jeweler’s screwdriver and dip the tip in isopropyl alcohol. (Don’t use any other solvent unless it’s designed for cleaning electronic parts!) Then touch the screwdriver tip to the pin. Do this several times until the pin area is nicely wet. Then push the pin up and down until it is able to spring up quickly.
Enjoy.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
