Disney Mix Max Digital Media Player Logo
Posted on Dec 25, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Disney mix max installation with Vista
I have windows vista and disney mix max player needs xp?
Am I out of luck or is there some other way to download installation?
  • 7 more comments
  • applebet Dec 26, 2007
    it is the same as the other guys
    i have windows vista and it isnt working with my disney mixmax digital media player
  • Anonymous Dec 26, 2007
    i switch between MSC & MTP and then install it but, no good
  • shellith Dec 26, 2007
    i have vista. does the disney mix max work with it?
  • Scrummage Dec 27, 2007
    I can't download with my windows vista on the disney mix it. I tried un installing it then re installing it, but it did not work.
  • Anonymous Dec 27, 2007
    Windows Vista download for Disney Mix Max
  • Flare Dec 28, 2007
    Why would Micro soft make Windows Vista not compatible with past windows versions? There better be a way around it or I'll be really mad! I bought 2 of these for both of my girls for Christmas!
  • Anonymous Sep 30, 2008
    is there a fix to this problem yet
  • mariana08 Dec 20, 2008
    I have the Mix Max and the Vista does´t work for it, what can I do?
Anonymous
Level 2:
Scholar:
  • Expert 93 Answers
  • Posted on Apr 01, 2008
Anonymous
Expert
Level 2:
Scholar:
Answers
93
Questions
0
Helped
30949
Points
125
You don't need the software, it's optional. You can still connect the player and sync audio to it with the sync page in Windows Media Player 11.
  • Anonymous Jun 04, 2013
    my computer said "the device plugged into the computer has malfunctioned and windows does not recognize it"
2helpful
3answers
How do i download music on my mp3 player?
How to Put Songs on Disney Mix Max
The Disney Mix Max portable media player is capable of playing audio files in the MP3 format. It can also play videos formatted as WMV and display photos formatted as JPEG. You can convert audio files into MP3 using the Disney Mix Max software -- Mix It Plug-in. The plug-in works with Windows Media Player 10. This software CD came with the player and is not available online. To download music to the device, you can use Windows Media Player 10 or Windows.
Things You'll Need:
* USB cable
* Mix It Plug-In installation CD
Instructions
Convert Non-MP3 Files
Install Mix It Plug-In. Insert the Mix It Plug-in installation CD into the computer's optical drive. Click "Install Mix It Plug-In" when prompted. If no screen opens, double-click on the "My Computer" icon. Double-click on the installation CD icon. Then double-click on the setup or installation file; this file is often formatted as EXE. Select to have the program saved to your desktop. Then double-click on the desktop icon -- "disneymixitplugin" to open the setup wizard. Click "Next" in the setup screen. Follow any additional setup prompts.
Open Windows Media Player 10 and create a playlist. To create a playlist, click "Library" and select "Now Playing." Drag songs from your computer to the "Now Playlist List" pane. Click the "Now Playing List" title to open the menu and select "Save Playlist As." In the "Save As" dialog box, enter a name for the playlist and select "Save."
Open Mix It Plug-In. Select "Yes" when asked to save analysis information for your music files. The software will analyze each track's compatibility with the Disney Mix Max player.
Press "Go!" to start the conversion process. Once the process is complete, an inactive "Go!" will be displayed. All music that has been converted is still listed in your Windows Media Player 10 playlist. You are now ready to download music to the player using Windows Media Player.
Open Windows Media Player 10 on your computer.
Remove the USB jack cover located on the bottom of the Disney Mix Max. Insert the compatible end of the USB cable into the USB port on the Disney Mix Max. Insert the other end of the cable into the computer's USB port.
Click "Library" and click a playlist name. To create a playlist, click "Library" and select "Now Playing." Drag songs from your computer to the "Now Playlist List" pane. Click the "Now Playing List" title to open the menu and select "Save Playlist As." In the "Save As" dialog box, enter a name for the playlist and select "Save."
Select the "Sync List" tab and choose "Sync List" from the menu.
Verify the items to be synced to the Mix Max, or right-click on a song title and select "Delete" to remove it. Click "Start Sync" to download music to the Mix Max.
Windows
Insert the USB cable to the Disney Mix Max USB jack. Connect the player to the computer with the USB cable.
Click on the desktop "Start" menu and choose "My Computer."
Double-click on the "Removable Disk" that corresponds with your connected device.
Drag songs saved on your computer with your mouse into the Removable Disk folder.
Tips & Warnings
If you converted files using the Mix It Plug-In, you will need to use Windows Media Player 10 to sync them to the player.
I have windows vista. how do i downloads music on
See my tip posted here, copy the address into a new tab. ---> http://www.fixya.com/support/r4055689-download_mp3s_player <----
Will this work with my Toshiba computer??
Yes. It should work with your computer with Windows XP or Vista installed.
When connected to usb, computer does not recognize unit. Also unit does not turn on.
hi there,
it might be broke
to check if u can access it via pc, make sure>
-u do have an USB 2.0 port
-u have installed the proper drivers
(see CD that came with it-there are drivers for win98, if your winversion is win98 t!)
-if u are using windows vista, this will cause trouble,hard to fix,
try to connect to an winxp or win2000-PC instead!
this device should not need any drivers to function, the manufacturer(disney) does not provide any drivers,
but a firmware(internal driver software)
update can be found...
if you accidentally erased it, check out disney.com !
download, install and update your driver...
good luck
here:
- a downloadable pdf-manual can be found at:
http://digiblue.com/customer-service/downloads/qsg/Disney_Mix_Max_Guide.pdf.
1helpful
I have lost the software to disney mix stick. Please help
Please confirm what operating system your computer runs (like Windows XP or Vista). Also, confirm if you are looking for its drivers or some other special software.
If your system is running Windows XP or Vista, you can simply plug the device in and it will automatically appear in Start > My Computer (or Computer). You can then simply drop your music files (such as MP3s) straight onto the device.
With regards.
8helpful
Unable to download mix max software!
The software will most likely not install on Vista and if it does it will probably fail to run correctly. However the software isn't necessary to be able to put music on the player. Just start Windows Media Player and go to the Sync screen. You'll see the Sync button in the top right. You'll see that it splits WMP into two fields, on the right is the sync list and on the left is the library of songs. All you have to do is drag the songs you want from the library on the left to the sync list on the right where it says "Drag items here to create a list to sync" and then click start sync. It will then begin copying the songs to the player.
I inserted the disk that came with the mix max player and you click the install tab and all that comes up is a bunch of jiberish that makes no sense. we are also still trying to find a place to purchase...
The disk that came with it doesn't seem to work for me with Windows Vista. Instead you can use it as a mass storage device.
The movies are hard to find. Try looking at http://store.digiblue.com/category_s/32.htm. That is the wedsite for the manufacturer. Also try Disney shopping.com.
1helpful
2answers
How do you put music on a Disney Mix Max (512 MB) Digital Media Player
I have Windows Vista and the first time I plugged in the Mix Max it immediately downloaded the device drivers. I opened my Windows Media Player and it already recognized the player. I just transferred songs over walla they are on the player. Hope that helps.
1helpful
Disney mixmax for vista
The software won't install but you don't need it in order to use it. It's a plug in that interfaces with Windows Media Player. Since Vista comes with Windows Media Player 11 you can just go to the sync page to add songs to the player.
Top Disney Audio Players & Recorders Experts
Alexander
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Are you a Disney Audio Player and Recorder Expert? Answer questions, earn points and help others
