Is there a leak somewhere? There should be green or pink fluid on the ground if there is. The plastic jug is often called the overflow this has level marks on the side of it for when the vehicle is hot and cold, cold is at the bottom end of the jug. The purpose of these marks is so you can see the levels without having to open the radiator. When the engine is cold open the radiator, start the motor and look into the radiator there should be coolant at the top of the opening. If not add coolant while engine is running, note if it's pink it's the DEX/Cool, if green any over the counter coolant will do. Add until the level hits the top of the opening. Let the engine heat up and check the level again. If it's full put cap back on and note the level in the overflow jug. If engine is hot level should be at the top mark, be sure to NOT fill the jug to the very top as it needs the space to expand for any over flow from the radiator.
The system will pull extra coolant from the jug when it's cold and use it until the proper temperature is reached then it will "spit" the extra back into the jug. (that's why there are two lines 'hot' and 'cold') Never add water to the jug as it will cause the jug to crack if the outside temperature goes below freezing always add coolant/antifreeze.
Is it the radiator or the overflow that won't stay full?
