Question about Makita 18V LXT Lithium - Ion Cordless Impact Driver Kit Model BTD140
Batteries show charged but no pwr
Batteries show charged as usual, but no sound or reaction whatsover from the drill - do these things just spontaneoulsly die like that? and if not, what would have cayused this?
thanks?
    Master:
  • 619 Answers
Clamp one side of [power line of your charger insert baterry pack,if amphere increase the battery pack was ok.select battery good one still run impact diver insert to the charger amphere increase good charger and battery pack. Two only the problem Battery pack or charger, if charger not function , the power transistor will be replace or buy new charger.
Posted on Jan 01, 2008
SOURCE:
18 V Ni-Cad charger repair
From what I've seen.....usually when Lithium batteries won't charge it's because they lost too much of there charge. As soon as a Lithium battery shows signs of weakness they should be charged. But to answer your question most chargers do have a fuse soldered to a circuit board so yes it's possible to be a fuse but not usually "simple".
Jan 01, 2013 | Porter Cable PCL318IDC-2 Tradesman 18V...
Just bought a new drill and battery not holding a charge
Batteries sometimes get like yours, after a full charge they last only a couple minutes on the tool. It's usually because of a bad cell in the battery. The only fix is to replace the battery. If you just bought it, take it back for an exchange of the battery or whole tool kit. If the retailer you bought it from won't exchange it contact the company it came from to find out how to get the battery replaced under their warranty.
Mar 01, 2012 | Drills
My 3 year old battery P104 will run my drill about 10 secs and then quit. I restart the drill and the same thing, another 10 secs and stop. I checked the voltage on the battery and it is fully charged. ...
Your batteries are tired and don't put out enough amps to power your drill. They may show 18V in them on a tester and show fully charged on the charger but one or more of the cells inside are just worn out. If you got three years out of them you did extremely well. The only fix is to replace the batteries.
Mar 04, 2011 | Ryobi Two 18V Lithium-Ion Batteries +...
Battery charger shows that the battery is fully charged - the green light is on. However, when the battery is reinstalled the drill doesn't operate??? Help!!
Your battery is only good for so many cycles, it sounds like you need a new battery. Check with Batteries plus they're a great source for about ANY battery
Jan 04, 2011 | Mx Black Max 24v Cordless 1/2 Inch Drill /...
How long do u charge a makita li-on battery cartriage for on the first charge? as the information booklet we got with it doesn't give the information
the charger should indicate when the battery is fully charger. look at the lights and they will show you. Usually though it is about an hour.
Jul 15, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Bought 2 no BTD142 impact drivers from Makita USA got drop down transformer they just start to charge then tones for broken battery are heard and stop charging, transformer new, batteries new have i done...
these newer chargers do make a tone that can be changed. when the batterys are initially inserted they will make a sound and then when they are fully charged they will make another usually longer sound. you can change it by removing the battery with 5 seconds and reinserting until you find the sound that you like.. I would look at the charging lights before deciding the charger or battery are bad.
Nov 22, 2009 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Drill causes my Battary to smoke & Burn out
Do you have more than one battery and if so do they both do this? It sounds like the batery has shorted out or possibly the switch is malfunctioning and creating the short either way I would not try and recharge a battery that has these symptoms. I actually had a NiCad battery catch on fire when I charged it not knowing the history of battery. There are repair centers that usually won't charge you to check batterys/drill or maybe a minimal fee but it is cheaper than replacing batterys constantly. Good luck. Dave
Dec 25, 2008 | Dewalt Drills
Ryobi cordless drill
sounds very much like the batterys we used to have ryobi drills but the batterys dont last now we use makita/dewalt/bosch
Oct 01, 2008 | Drills
Makita 18V LXT Lithium - Ion Cordless Impact Driver Kit Model BTD140 Logo
193 people viewed this question
Top Makita Drills Experts
John Trevino
Marvin
Marvin
Spud Howell
Are you a Makita Drill Expert? Answer questions, earn points and help others
