Through the All Programs menu:
1.
Click
Start.
2.
Point to
All Programs.
3.
Point to
Accessories.
4.
Point to
System Tools.
5.
Click
System Restore.
6.
Follow the instructions on the wizard.
Creating
a restore point can be useful any time you anticipate making changes to
your computer that are risky or might make your computer unstable. If
something goes wrong, you select the restore point you just created and
Windows XP undoes any system changes made since that time.
Create a Restore Point
1.
Open System Restore. (See step-by-step instructions above.)
2.
Click
Create a restore point, and then click
Next.
3.
In the
Restore point description
box, type a name to identify this restore point as seen in Figure 1
below. System Restore automatically adds the date and time that this
Restore Point is created.
Figure 1. Creating a restore point
To finish creating this restore point, click
Create.
To cancel restore point creation and return to the
Welcome to System Restore screen, click
Back.
To cancel restore point creation and exit the System Restore Wizard, click
Cancel.
To view or to return to this restore point, from the
Welcome to System Restore screen of the System Restore Wizard select
Restore my computer to an earlier time. Then select the date you created the restore point from the calendar in the
Select a Restore Point
screen. All of the restore points you created and you computer created
on the selected date are listed by name in the list box to the right of
the calendar.
Note System Restore does not replace the
process of uninstalling a program. To completely remove the files
installed by a program, you must remove the program using Add or Remove
Programs in Control Panel or the program's own uninstall program. To
open Add or Remove Programs, click Start, click Control Panel, and then
click Add or Remove Programs.
I will certainly try this although I was told that a non oem copy would have different drivers, and I know on a fresh install it tells me I am using it on the wrong model, I will try though and see what happens I will get back to you tommorow, and thank you.
which bittorrent sites can I download an oem copy of windows from?
