Sony PlayStation 2 Slimline Console Logo
Posted on Dec 25, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Leapster wont switch on
Hi i have a leapster but it wont switch on I also have no manual if i could just find the manual id sort it out Hi, jimz4 here, I also have same problem with Leapster not powering up, have new batteries, cleaned connections, used the rechargable station battery pack, nothing worked, it turns on but does no power to a screen to play. Please help with kids xmas gift!
  • 2 more comments
  • jimz4 Dec 26, 2007
    This is not a solution to my problem with the leapster, it turns on but the screen will not respond. It is divided into four sections that are square. Some music plays after the on button is pushed, then the screen displays the four squares but then it will not respond. This is my problem. Do you have the solution?
    Yes, that is a better discription of problem.
    The music plays the screen comes on with the four squares and the bottom left square has two shapes inside it, a smaller square and a rectangle standing long side up. Then it does not respond. Clear enough now?
  • jimz4 Dec 27, 2007
    Sorry for the trouble, but...that link just took me to the screen to sign up to be expert. I looked throught the problems listed all 18 pages could not find anything that helped. I do not think that the screen freezing on a leapster is same as a tv. What exactly is your solution so I can try it and tell you if it helps. Do not know what tat means...or if not means say means. Thanks and again sorry for the ignorance.
    This is a discription of problem with the Leapster; After pressing the on buttom the music starts to play and the screen lights up and displays four squares and the bottom left square has two shapes inside it, a smaller square and a rectangle standing long side up. The music stops and then the screen is frozen. I suppose it is defective? any soloution for jimz4?
Anonymous
Level 2:
Sergeant:
  • Expert 279 Answers
  • Posted on Dec 27, 2007
Anonymous
Expert
Level 2:
Sergeant:
Answers
279
Questions
0
Helped
139990
Points
557
First let me say there was some confusion here. The question you posted was under the category of Playstation 2. Sweet_rascal apparently didn't realize you were talking about a Leapster not a PS2, so please disregard his comments. It's likely he doesn't have any experience with the Leapster. I have 2 young girls at home, however, so I am very familiar with it.
One thing you can try - if it gets that far, is recalibrating it:
Insert a cartridge, turn the unit on and wait for the sign-in screen to appear.
Hold down the Home, Hint and B buttons simultaneously.
When the screen changes, press the A button.
Using the Stylus, touch the center of the targets.
See if that helps at all, though I'm not sure it will from your description of the problem. But, it's somewhere to start. I'm looking for more information now.
-Dyllan
  • Anonymous Dec 27, 2007
    This may sound silly, but sometimes it's overlooked. There should be two contrast knobs on the bottom of the Leapster. Have you tried adjusting those to see if it brings the screen up? If they're adjusted too dim, it actually removes all display from the screen.
    Okay, found some more information.
    Apparently a number of Leapster units have had problems with their screens. If calibration (as I suggested above) doesn't work, and the contrast knobs are not the problem, you should call LeapFrog: 1-800-701-5327
    Their hours are:
    5 - 7 M-F (PT)
    7 - 4 Sat. (PT)
    They have been replacing damaged units if calibration doesn't fix the problem.
    Let me know how all of this works for you, and if there's anything else I can do to help.
    And again, my apologies for the confusion with sweet_rascal.
    -Dyllan
Anonymous
Level 3:
Guru:
  • Master 1,894 Answers
  • Posted on Dec 25, 2007
Anonymous
Master
Level 3:
Guru:
Answers
1894
Questions
13
Helped
563503
Points
4850
If the light goes green for a very short period before going red again it means theres a short on the circuit board. u can try and find the problem but because the circuitry is very small, it wont be easy to find. only other solution is to buy a new circuit board :(
  • 3 more comments
  • Anonymous Dec 25, 2007
    The red light is on, but when we try to push the button to turn it on, it wont do anything..... if problem is like this..
    Check to see if the ribbon cable from the power switch is seated the socket properly. Otherwise,
    I believe your PS2 has a short circuit and needs another motherboard. If you can do this yourself, that’s great. You can find Motherboards or PS2 like yours that will not read discs but
    will boot up for about $25 on Ebay. If you’re not comfortable
    with Changing out your motherboard, then click on the "Repair
    directory" at the bottom of this screen. On the Repair Directory
    Screen, select Video Game Consoles. Choose a good Repair shop.
  • Anonymous Dec 26, 2007
    is your problem the freezing fo the screen as soon as the system starts?
    plz be clear
    this problem was being discussed yestarday. i dono tat user has tried it or not. til now he dint give any feed back.
    http://www.fixya.com/support/t312186-scr...
    this s link of tat problem...
    see the solutiions...
    and try if it helps.. if not means say
    sorry to say.. i cant solve this problem without seeing it in person..
    calling a service person will help you a lot i think..
    i tried my my level best.. thank u for your response
How do you make your leapster leapfrog explorer turn on
Hi. I found these instructions for turning your Leapster Leapfrog Explorer on here:
http://www.ehow.com/how_7707353_leap-frog-leapster-wont-turn.html
1helpful
Leapster wont power on?
Take a fine file or sand paper to the connections this usually works.
My leapster wont reconize the camera
I had the same exact problem. I even tried another camera with no luck. I ended up updating the firmware/software on the Leapster Explorer and the camera started working. Here is a link to the Leapster website showing you how this is done:
http://leapfrog.custhelp.com/app/answers/detail/a_id/2090/~/error-52%3A-update-software
Manual for Leapster 2
I need to change names. I hooked it to computer, iT DIDNT OPEN UP EVEN THOGH IT SAID IT DOWNLOADED DRIVER. The screen on Leapster says Do Not Disconnect. I dont know what to do
Hi my daughter's leapster screen is not
THE SENSOR IS BAD ,TAKE IT BACK TO STORE AND ASK FOR ANOTHER ONE,IF BOUGHT AT WAL-MART AND THEY GIVE U PROBLEM TELL THEM U R GOIN TO CALL 1 800 WAL MART THEN DO IT WHILE IN STORE THEY WILL MAKE THEM EXCHANGE IT
3answers
Leapster pen or touch broken
leapster 2 comes on but when you touch screen with pin wont do anything
12helpful
3answers
Owners manual
how do I remove the names that were originally put in and add my sons name to the leapster 2
32helpful
11answers
Hold down the powerbutton for 3-5 seconds then release.
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
