Got beeping? I JUST figured out how to fix it. Take the console apart and pull the connector from the back of the iFit card adapter. Plug back in, should be good as new!
Absolutely fantastic advice! We did as you suggested (except we left the connector unplugged - it stopped working when we plugged it in and we don't use the iFit anyway). Now the treadmill works wonderfully! Thanks!
I followed these same directions for my Nordic Track NTL09007 C2500 and it worked perfectly. I followed the fat data ribbon cable from the iFit card reader to the main board and disconnected it there. My wife thinks I'm a genius. (fooled her) Thank you for the instructions!
I had the same problem, console lit up but no functions. Unplugged the iFit from the console and wa-la, it worked again. I didn't try pluggin it back in again since I've never used it. Thanks for the help everyone
I had exact same problem console lit up and beeps but nothing moved after I read Mr. Humston's very help full comment I opened the console, it took me little while and few try till I found the right connector and wa la everything start working . When I called the Nordic track they said I have to replace the whole console and the cost was $600 but thanks to Michael Humston for the great discovery and advice .Thanks
I have the exact same problem after a year. Haven't fixed it yet. They told me the same thing.
I have the same problem as well, it is so frustrating I bought this and was so excited to replace my old one and I am still using a 10yr old treadmill. I cannot possibly afford the board.
On our machine the console would light up and the mileage would start counting, but no motor. I checked the motor brushes and fount that the bottom one was popped out.Take the top off (3 screws front edge, 1 underneath, will have to tilt the machine back to get the bottom one) and check the brushes. You might have to unbolt the motor (pain to get it back on).
Our C2500 stopped working a few years ago and I'd read to stick the memory card in. Sure enough, after I'd found it everything worked ... for about 4 years. This time it would come on but the belt wouldn't run and the control wouldn't let you change display. I went into it and unplug the iFit from the console, and all is back to normal. Thanks for the advice!
