Hello Ron,
If you have already replaced the thermostat unit and both heating elements, and the indicator light is coming on and the fans are running, but the oven is still not heating up, here are some additional troubleshooting steps you could try:
- Check the wiring connections: Ensure that all wiring connections are secure and properly connected. Loose or faulty connections can prevent the oven from heating up.
- Check the oven control board: The control board regulates the power to the oven elements. If it is faulty, it may prevent the elements from heating up. You can test the control board using a multimeter or by having it professionally checked and repaired or replaced.
- Check the thermal fuse: Some ovens have a thermal fuse that protects the oven from overheating. If the thermal fuse has blown, it can prevent the oven from heating up. You can test the thermal fuse with a multimeter and replace it if necessary.
- Check the temperature sensor: The temperature sensor is responsible for monitoring the temperature inside the oven. If it is faulty, it may prevent the oven from heating up. You can test the temperature sensor with a multimeter and replace it if necessary.
If none of these steps resolves the issue, it may be best to contact a professional repair service or the manufacturer for further assistance.
I have exactly the same issue, fan assisted oven setting - no heat (fan is working fine I feel) the non fan setting heats up ok but then appears to lose it's temperature.....(not that the thermostat knows about!)
Can't believe my oven has two separate elements..........Please help
Your convection element has go bad in the back wall I'm sure.
