Hitachi convergence problem
You need to re-solder the circuit board that contains the STK
convergence modules. They're on the center circuit board attached to an
aluminum heat sink that's about 8" long and 6" tall, about dead center
in the circuit board. You may be able to recreate the problem (hour
glass effect) by gently moving the heat sink (which the modules are
connected to). This gives the hour glass effect on the picture and the
advanced convergence screen. This is an indication that the modules
pins aren't solidly connected (meaning soldered) properly. Remove the
circuit board and clean the old solder off & resolder the modules
pins to the circuit board reconnected the board and then retest by
again pushing on the heat sink. Take the appropriate cautions
working around the high voltage of the set & use a non-conduting
piece of wood to push the heat sink when we doing tests.
Best of luck, hope ya fix it.
