SOURCE: The drum light came on
I continued looking and found where someone else had the same problem. I opened the front cover, held down the go key for 10 seconds and closed the door. This reset something because it works now.
Thanks
SOURCE: Brother HL 5240 won't print
Right Click on My Computer, and select Manage. Look at Device Manager and look for any yellow exclamation marks. It may not be installed.
SOURCE: Brother HL 5240 printer: Drum light flashing
you need to replace drum cartridge, when you buy one back ,look new one then you'll find out where is the drum.
SOURCE: How do you replace the drum properly on a Brother
Out with the old and in with the new, you remove the toner and drum together, remove the toner from the old drum by pressing the blue lever on the side, install the toner in the new drum, and re install in the printer. With the front door open press the go button til all lights flash and then close the door, the new drum is reset.
