Question about NorStar M7324 Telephone
Auto attendent voicemail locked
I have the Nortel M7324 phone at the reception desk. I have no problem resetting the password for any other voicemail EXCEPT the reception desk phone which is where the auto attendent / general voicemails drop into. It seems i'm locked out and i can't figure out how to unlock it using my admin password or F983. Any suggestions?
  • 52 Answers
Go to this phone press feature 983 this takes you to admin change mail box .The general mbox is 100 this is the mbox you want to change
Posted on Oct 09, 2009
SOURCE:
When logging into the voicemail for a Nortel T7316E i get the Mbox Locked warning. I have followed the steps to reset my password and have successfully done that. I then proceed to access my voicemail with...
You're resetting the wrong password. Keep in mind that mailbox numbers and extension numbers are not always the same. When you're resetting the password, make sure that the EXT assigned to it is the right one !! If you're resetting the reception mailbox, it's usually mailbox 100 (regardless of what the extension number is)
May 10, 2011 | NorStar T7316E Corded Phone
I have a Nortel T7316E phone at work. We have extensions but don't have direct dial; only a receptionist that can place calls into our voicemail. My question is, how can I check my voicemail remotely after...
Depends on the voicemail, but generally:
Call the receptionist
When the auto attendant answers, press * (or sometimes "**"), OR ask the operator to transfer to your line and press "*" during your message.
It will ask you your login information.
Dial your extension and password together as one number and press #
You can now operate the voice mail.
Mar 16, 2011 | NorStar T7316E Phone
How to get voicemail from another phone nortel 7316e I am trying to get my office messaged from my cell.
If your trying to get your messages from another nortel set in the office press your open voicemail button or feature 981. The left soft key below the screen should say OTHR. press the soft key the screen should change to LOG: enter in the mailbox number followed by the password and #.
If your trying to get your messages remotely, call into the office and when the auto attendant answers, press ** followed by your mailbox number password and #.
Nov 02, 2009 | Nortel T7316E 2-Line Corded Phone
Nortel 7316e: Need to change the auto attendant
To enter viocemail administration, press Feature 983. if your system has 2 digit intercom #s your password is 120000 if your system has 3 digit intercom #s your password is 1020000. once you have entered the password you will see 3 selections you can make .use the three soft keys under the display and select AA (auto Attendant). next press greeting and greeting again. next it'll ask for the greeting number your probably working with greeting 1. press record to start and ok when finished. dont forget to save the greeting or it will be deleted if you exit early. hang up when finished
Oct 27, 2009 | Nortel T7316E 2-Line Corded Phone
How do we reset a voicemail password for a Nortel M7324 phone?
press feature 983 the screen should say log:
enter 1020000 (default password) if you have a 3 digit intercom number, 120000 if you have a 2 digit intercom number
the display should say mbox, AA, and othr above the three soft keys
press the mbox soft key
the screen should say add, del, and chng above the soft keys
press the chng soft key
enter in the mailbox number you wish to reset the password on
press ok
the screen should say reset and next above the soft keys
press the reset soft key
press the Rls key
your password should be reset to 0000
Oct 20, 2009 | Lands Phones
My nortel voicemail is locked
What password is no longer valid? The admin, the operator, the installer?
What are you pressing to log in?
Jul 07, 2009 | Nortel Business Series Terminal T7208 -...
Getting rid of automatic transfer
you need to change the zero / timeout transfer for the auto attendant programming to go to a general mail box. do you have the manual?
Jul 06, 2009 | Lucent PARTNER18 Corded Phone
Night ring change the number of rings
Auto Attendant
Answer Lines
1 – Feature 983
2 – Log: Dial 1020000 (3-digit DNs) or 120000 (2-digit DNs)
3 – Press AA
4 – Press LINES
5 – Line number: Dial line number (001-xxx).
6 – Line:xxx Ans:No Press CHNG to AA if auto attendant will always answer theline. If a Night Service key will be used to activate auto attendant answering, leave Ans: at No.
7 – If line has been changed to Ans:AA, press * then press TABLE.
8 – If Table:1 is OK press RINGS. (Table 1 is the default greeting table. Change to a different table (1-4) if alternate answering is required on the line being programmed.)
9 – Rings:0 – Press CHNG, dial number of rings before auto attendant answers the line, or leave at 0 for immediate answering. Allow at least 2 rings if CLID is in use.
10 – Repeat for each line to be programmed.
Notes For Night Service Mode Auto Attendant Answering
If the auto attendant will only answer lines in night service mode, line answering should be set to No as per step 6 above. Using night service will cause the AA to answer lines immediately.
Feb 11, 2009 | NorStar M7324 Telephone
Voice Mail Access with No Phone Terminal
you should be able to dial the voicemal system internally and it will prompt you for your box number and code, or from outside the system there should be a code that will allow you to enter voicemail from the main menu of the auto attendant
Dec 23, 2008 | NorStar M7324 Telephone
NorStar M7324 Telephone Logo
669 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
Thomas F. Schneider
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
