I need code to enter on TiVo remote for the below RCA TV to be able to turn RCA on and off from TiVo remote.RCA Model # L32HD31R
None of these codes, nor the learning code cycling through all codes is working for RCA tv and Tivo peanut remote.
Go to http://support.tivo.com/app/answers/detail/a_id/294/kw/code%20search/c/105/r_id/100041 and under Programming TV Power, Volume and Mute, click on "show the steps".
Follow the instructions given.
The RCA remote codes are 0163, 0001, 0004, 0006, 0011, 0029, 0030, 0057, 0071, 0133, 0145, 0106, 0171, 0231, 0232, and 2210.
Try each of these codes one at a time (as per instructions) until you find one that works.
This link also gives instructions on what to do if none of the above codes work.
If this helps, please give a rating!
Hi- My name is Shannon and I am with Suddenlink. The SL-TiVo remote can be programmed to control the TV and one other A/V device using these steps:
1) From TiVo Central, select Settings & Messages > Settings > Remote, CableCARD, & Devices > Remote Control.
2) Highlight Part 1: TV power, volume, and mute and press SELECT.
3) The DVR displays a list of television brands. Use the UP ARROW and DOWN ARROW buttons and the CHAN DOWN and CHAN UP buttons on the TiVo remote to highlight your TV brand and then press SELECT.
4) The TV Remote Codes screen appears. Follow the instructions on this screen to enter a code into your remote control. If the first code does not work, repeat the instructions to enter the second remote control code, and so forth, until you find a code that works. The remote is now programmed to operate the TV.
5) If also programming to control volume & mute on an A/V receiver for surround sound; Highlight Part 2: A/V volume and mute and press SELECT.
6) The DVR displays a list of audio/video receiver brands. Use the UP ARROW and DOWN ARROW buttons and the CHAN DOWN and CHAN UP buttons on the TiVo remote to highlight your receiver brand and then press SELECT.
7) The AV Remote Codes screen appears.
Follow the instructions on this screen to enter a code into your remote control. If the first code does not work, repeat the instructions to enter the second remote control code, and so forth, until you find a code that works. The remote is now programmed to operate the receiver.
The TiVo remote will now turn the TV on/off and switch inputs and adjust the volume and mute the audio on the receiver.
If you have any questions, feel free to email me at shannon-AT-suddenlink-DOT-com. Thanks!
I knew all that - that's what TiVo says - I asked because none of the codes given by TiVo worked.
I've tried all the codes and also the outrageous total search to no avail.
