Watches Logo
Posted on Oct 09, 2009
How do I change my Casio twin sensor alti thermo watch from 24 hour to 12 hour format?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 21, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2173
Points
12
Press and hold the top left button for 2 seconds to go into the time adjustment mode.
While you are in this mode press the top right button to switch between 12 hour and 24 hour modes.
Press top left to return to normal.
1helpful
Change from 24 to 12 hour format on casio 3239
To Toggle between 12-hour and 24-hour timekeeping:
In the Timekeeping Mode (regular watch display), press the lower right-hand button to toggle between 12 and 24 hour timekeeping.
Change from 12 hour to 24 hour format
You can download the manual from the link below. The information you requested can be found on page 2 (left column).
http://support.casio.com/en/manual/009/qw3768.pdf
Set time format from 12 hr to 24 hr for casio LA670W
Was this problem answered? If yes, can somebody tell me how. My Casio LA670W is in 24hr format and I want it back on 12hr format. My watch have 3 buttons only. Mode, Start-Stop and Timer
1helpful
12 hours early
Try this:-
First set the watch to 24 hour format rather than 12 hour format.
1helpful
How to adjust the time on a CASIO W-59 watch
Hi Harry,
Your Module number is 2271.
1. To set the time, press and hold button A (left top) until Seconds digits start to flash.
2. Press button D (lower left) to move flashing in the following sequence to change other setting:
Seconds >> Hour >> Minutes >> 12/24 Hour Format >> Year >> Month >> Day >> (Then back to Seconds)
3. While a setting is flashing, use E (+) (bottom right) and B (-) (top right) to change it.
Note: When in the 12/24 Hour Mode, use E and B to toggle between 12-Hour and 24-Hour Mode.
4. Press buton A to exit setting screen.
Your time should now be set.
You may also download a manual for watch/Module number:
http://pathfinder.casio.com/resource/manuals/module_2271.pdf
This should give you all the info you need to operate all the functions of your watch. Thanks.
Regards, Bill
Sep 27, 2010 • Watches
3helpful
How can I change on casio alti thermo prt-30 from feet into meter
I've been giving this advice to many other Casio uowners, but it much quicker and easier, if you will take your four-digit caliber number from the watch back, go to this link, and enter it there for a complete PDF file about your watch.
http://world.casio.com/wat/download/en/manual/
Good luck! Bill
Where can I get the manual for Casio Alti Thermo Twin Sensor (the old one)?
mcdevito75 here, Here is Casio"s contact info, 800-435-7732 hope they can help.
2helpful
2answers
Changing time on Casio Alti Thermo
Click on my profile (escapement), then click on Tips and Tricks. There you will find links to all watch manuals. Rate me, please .
Changing from 24 hour to 12 hour system
Follow this link and find out what you want:
Rate me, please.
Top Casio Watches Experts
k24674
Robert
ZJ Limited
ZJ Limited
Are you a Casio Watch Expert? Answer questions, earn points and help others
