I had a probelm with the A drive and had to remove the front panel to replace it. I mistakenly removed three connectors from the MB & did not notice were they went. They are as stated PWR Led (blue/white)/ HDR Led (red/white) & PWR S/W (black/white) they connect to a nine pin area J9G1. I have tried diagrams from the Intel site but to no avail. I am not able to power on my childrens Pc, please I need help. Or could it be something else? The green light is on when it is connected to power, FYI.
The diagram for that 9 pin J9G1 is alongside the CMOS battery.
I had the dead PS/MB problem on the emachine T2742.
Intel® Desktop Board D845GVSR
Manual (Product guide)
http://download.intel.com/support/motherboards/desktop/D845GVSR/SR_English.pdf
If you want to purchase a new MB or MB w/processor at a reasonable price, I found this site >
http://oemxs.us/shopping/index.php?target=products&mode=search&subcats=Y&type=extended&avail=Y&pshort=Y&pfull=Y&pname=Y&pkeywords=Y&q=BOXD845GVSR
F.Y.I., any standard ATX power supply @ 250W or better should work in this box. I picked mine up at a swap meet for $5.00.
Hope this helps!
-Larry
Set jumper on cmos to 2 and 3 when computer is off.when boots press f10 and save.turn off computer and put the settings back to 1 and 3
You should be able to mach them up if not turn off computer and hook them up anywhere and turn back on till you find where it goes.
Intel Desktop Board D845EPI/D845GVSR
computer turn off jumper norma?
pls solution my computer.
Comment by Guest, posted on Jan 19, 2008 eMachine T2742 will not turn on! I replaced the Power Supply and I am able to see the green light shine on the motherboard which is a step in the right direction ..i HAVE THE SAME PROBLEM..WHERE CAN I GET A NEW MOTHERBOARD? PLEASE ADVISE ME TO FING IT
Check the capacitors near the fan. I had the same problem and saw that the capacitors had overheated.
PC will not power up. Removed P/S and had it tested, it is okay. Also tested push button (ON/OFF) switch (momentary) this also test okay. Is there something on the mother board I can replace to fix this problem????
eMachine T2742 will not turn on! I replaced the Power Supply and I am able to see the green light shine on the motherboard which is a step in the right direction. But it will not turn on when I hit the button, I removed the color wires going to the motherboard and replaced them. My next step is to check the on off switch in the front.
I mistakenly remove the connector(power switch, HDD LED,and Power Led) from 9 pin MB connector which have no label and I dont know which is which.
Thanks
Joe
This is freaky as I too have lost the ability to turn the PC on - they (emachines / gateway) "made" me buy a new powersupply but this doesn't fix the problem and in the process I too have removed these 3 pins (thinking they were connected together) and now don't knmow which is which...hope someone can help
Thanks
Patrick
I need the wiring diagram for this board.
Will it be possible to email me.
thanks for the help
Regards
[email protected]
I was given an emachineT2742 that would not turn on. I replaced the power supply, and that did nothing. I replaced the power switch, but still nothing. If anyone has an idea other than a fried motherboard, I would sincerely appreciate the feedback.
The wiring on the panal header J9G1 has come off in transit, I can't get the PC to power up, I can get the red LED light on front panal to come on, but can you tell me the correct order I should put the other colour wires.
mistakenly remove the connector(power switch, HDD LED,and Power Led) from 9 pin MB connector which have no label and I dont know which is which.D845EPI/D845GVSr
