Samsung YPT9 Digital Media Player Logo
Posted on Oct 09, 2009
Will not charge. get a Power Surge error when plugging it into my PC.
Anonymous
Level 1:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Oct 09, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
10
Questions
0
Helped
1619
Points
22
Maybe The Battery On The Mp3 Player Is Dead And The Symbol Is Indicating The Batter Cant Take More Charge Since Its Dead
1helpful
HP probook 4540s plugged in not charging
Simply unplug the power from the adapter, leave for some minutes then reconnect.
Compaq CQ4010F Desktop PC won't turn on after a power surge
You probably and lets hope so, have an Electro Static Charge Buildup on your desktop. Remove the Power Cord and Press and Hold the Power Button for 30 seconds. After 30 Seconds plug the Power Cord back in the hit the Power Button. If it boots then you had an Static Charge Buildup. If it does not boot and you say it happened after a power surge then either your Power Supply or Motherboard is possibly damaged. Do you hear fans, hear the disk drive running, see lights, hear the CD Rom click once and see the light on the CD Rom drive com on briefly after you hit the Power Button. If so it would seem that your power supply is ok.
My laptop pluged in but not charging
There could be many problems with your laptopFirst, check if your laptop was plugged into a surge protector (ex. Power Strip). If it wasn't, a surge could destroy the charger, power supply, or even motherboard.
Second, try a different charger. If it was the charger that broke, then try a different one. I have had this happen to many off my computers over the years.
If it is fried, take it to Staples, or a local computer shop. I would always recommend plugging computers into surge protectors. Good luck!
I have a toshiba tecra m4-s435. i plug it in to try to use it and the charging light just blinks i got a 12311 error code off it but i cant find the code anywhere to help me with this problem. i asked...
Error codes are only of use by the Toshiba Technical staff and of no use to you as the consumer.
If you report that to the Toshiba Technical personnel, they can transcribe the error number for you.
If a blinking light comes on when charging, sometimes it indicates No Charge or the power cell inside the computer is not accepting a charge and will not function. You might replace the power battery if it has been in there for several years. They do tend to die after a while. As for the computer, it should operated without the battery. If it fails to boot when the power adapter is plugged in, then one of two issues are common. 1, the power adapter is faulty and needs replacement. 2. the computers CPU may be damaged by a power surge and that is bad news.
2answers
I can't charge iPhone, I got power surge warrning on my computer
hello friend,
maybe your cable of charging is nit genuine,
if warning displays in your phone then there is the problem in cable
and if the error displays in computer then the problem should be in battery or main board
When plugged into pc get error on pc power surge on usb hub port
Some computers have a limited power capacity on the USB ports, another possibility is that your gps battery is too low to be charged via the USB connection, try charging it with a wall or car adapter first, then connect to your pc.
Power Surge on USB Port
I'm assuming you're not using a hub but plugging directly into one of the USB ports on your laptop?
First, have you installed all current patches for your PC? I think this was a common error message that was hotfixed some time ago, so be sure your OS is up-to-date. If so, you could try to uninstall all USB ports in device manager, then restart. When your system is up, go to the first USB device and right-click, then turn off warning messages. This is just for the error message, you may have a problem with your Zen as well so try it on a different PC if possible but I'd do that when it's fully charged. You may need to do a hard reset (instructions in your manual) to get it to work but that may delete all of the Zen's contents, so that's a last resort.
Power Surge on Hub Port
hi, Please reinstall the chipset drivers and "Turn off the error messages from Device Manager => USB Host Controller => Advanced Tab => check mark "Don't tell me about USB errors"
Laptop battery is not charging
you need to repalce the battery, it will only work on AC power only now as the power surge damaged the battery, thank your lucky stars that the surge didn't blow the whole laptop because 98% of the time it does!
Surge Protector
Surge Protectors are devices that usually you plug your equipment to.. and it protects it from Voltage Spikes that would otherwise destroy the device without it.. saddly not all Surge Protectors are the sam.. some are completely useless..
If you are really serious about protecting your PC not just the hardware but also the data and your work.. might as well invest on a UPS(Uninterrupted Power Supply) unit.. it has everything a surge protector can offer and more..
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
