Expert
- Posted on Nov 23, 2009
Re: Krauly does not sit flat on bottom of pool floor,...
Check the dive/float assembly. It's the dual float with arms that is hinges off of the main body. It should be near the bottom, if it has come loose and is near the top of the unit, it will cause the problems you mentioned. You may have to replace the weight holder to fix it.
