Yes, mine, about a year old, for the past 6 months or so, it seems to be stuck on an effect, but I don't have any effect selected.Yes, mine, about a year old, for the past 6 months or so, it seems to be stuck on an effect, but I don't have any effect selected.
You can't post conmments that contain an email address.
Your best bet is to go to Market app on your phone. This is Google's version of the App Store. From here you can get lots of different programs for your phone.
If you do a search for "Photo effects" you should get a few different links. Be aware though, some of them will have to be paid for.
Sounds like youve got the Realtek soundcard software. You have got the sound effects which are built into the software turned on. You should see the Realtek sound manager icon in the bottom right taskbar just right click on that and go through all the options making sure no effects are enabled. Also right click the speaker icon then recording devices and go through all the settings there as sometimes there is also a box needed to check to disable sound effects even though it says none in the Realtek manager. Cheers from Scott and please dont forget to vote
Gently tap the lens with a stick and see if the dirt will fall to the side. It may of course migrate back, but as long as it doesn't stick to the lens, it will be out of the way for most pictures when the aperture closes. If it is stuck to the lens, have it professionally cleaned, OR take consulation in the fact that closer dirt is to the "optical center" of a lens, the less effect it has on normal pictures- pictures of bright objects are different though
Switch needs replaced in dash. you will have to take it out of the car and put a new fan switch, should work in all positions, and since its stuck that would be what I would replace first, not sure on procedure. http://hyundaisonata.com
Make sure your zoom is not set to low also switch on the antishake in the camera menu.
Turn picture quality down slightly to either 6 or even 5mp ( I know whats the oint in a 8mp if you are going to turn it down) believe me it works better.
The Windows Mobile installation may be corrupted.
The only way to fix that problem is by re-installing the windows software on the phone.
You can get the software for the T-mobile dash at the following link: http://www.t-mobile.com/wmupgrade/
Be warned that if you use this method most of the data on the phone will be lost, like text messages and etc. Your contacts should be fine as the are stored on the SIM Card and if you have been syncing your contacts with your PC then they should get loaded when you do the up
it will be a problem in its camera settings check its brightness,
contrast, effects should be none. if this doesnt help then restore its
factory defaults and then enter its security code or take it to the
service center
This is a CCD sensor problem and should be replaced. Try to have it done free of charge by Sony even though your camera is an old model because CCD sensor should last 10 years +.
