Programming should be done from the M7310, M7324 or the T7316E set. Administration access code: Feature * * 2 3 6 4 6 which also is Feature * * A D M I N.
If asked for a password enter the same 2 3 6 4 6.
If that doesn't work you may have the newer Compact ICS or the Modulur 0x32 control unit wish will be Feature * * 8 4 6 3 which is T I M E. Password is 2 2 7 4 2 which is B A S I C or A D M I N which is 2 3 6 4 6.
When in programming just press the next button(lower right arrow) until you see what you want to change. Then press show ( top right arrow) ,then change if you want to change it. If you pass it, just press back (lower left)
Example: To change the Time & Date Press next until you see Time & Date. Then show Then change Then change again, change it if you need to, Then next again until you see what you need to change. For example; only the hour needs to be changed for day light savings time. Just press next until you come to the Hour. Then Change it. Then press release RLs when your done.
