BOSS DD3 STAYS ON AND WILL NOT SWITCH OFF. EVERY TIME I PLUG IN THE INPUT THE LED STAYS ON.
It's supposed to do that. An extra lug on the input jack is connected to the battery and/or power supply's ground.
So the only way to power off any pedal is to disconnect the input jack. If you use a power supply and power multiple pedals you can simply disconnect the power supply to cut power and avoid unplugging each one.
the effects will not switch off when you stomp the pedal.
