Hi I have a zhone 6218 and I was having a conflict with ip addresses (zhone and linksys were both set to 192.168.1.1) so I changed the zhone to 192.168.123.1 now I am unable to connect to the zhone (I get an ip address assigned to me) but when I enter http://192.168.123.1 into IE I instantly get unable to view webpage... I tried telnet also but telnet just sits there with blank screen no option to enter un or pw... Any ideas how to connect to router again? I can't restore defaults as it will erase stuff needed for tv (entone)
Hi, i have the same problem that cannot connect to router after i changed ip address... i set my network connection to ip address 192.168.254.2 & subnet mask 255.255.255.0 & default gateway to 192.168.254.254... i can ping ip address 192.168.254.254 but cannot get into the web browser... i cant go back the router configuration page... pls. help... my router is zhone 6218...
Cannot connect
The problem is y did u change in that way? U have to use same subnet address. Change Zhone's IP address to 192.168.1.X
Then another thing is disable dhcp from the router which is not connected to the PC.
Set the default gateway of the PC to the attached router. Set the attached routers default gateway to the router at the other end.
That will solve your problems.
Please rate the answer.
Thanks
Goo Luck
Try the configuration connected to the Zhone instead of the linksys.
You can probably configure both from the zhone yet only the linksys from the linksys. I believe routers expect configuration requests from their lan side ports and not the wan port.
When connected to the zhone do the following
(assuming Windows XP)
Start then All Programs then Accessories then Command Prompt
Enter the following command (1 space after /)
ipconfig /all
In the resulting display you should see a default gateway address -- that should be the address of the router you are attached to. If it is not 192.168.123.1 as you expect -- it should give you access to the router.
If the above does not work statically address the Network adapter in the computer to avoid the DHCP issue and you may then get access to the router.
Like
iP Address 192.168.123.15
Subnet Mask 255.255.255.0
Default Gateway 192.168.123.1
Glad it is working now.
I have tried it direcly connected (hardwired and wireless) to the zhone. I am wandering if dhcp start address is 192.168.123.1 (router ip address)? opps if it is... whould this cause this behavior?
Thanks for the input, but I tried all that stuff before I fixed it, It had me puzzled big time, but what I did to fix it was I downloaded the config file off another router (same setup with tv and all) and restored defaults (held reset button on back of router) then connected to 192.168.1.1 as i did before and restored the backup config file i downloaded. Now all is well again... To fix the conflict I was having I changed the other routers ip as I can connect to it after changing it... It must be a bug in zhone router???
I have a zhone 6218 dsl moden and I cant access the modem when I check using Ipconfig at the dos prompt I received the following info
ip address:169.254.137.241
Subnet mask: 255.255.0.0
Default gateway: this field is blank
i have beetel 220 router. i have enabled access control management in router and accidenty deleted the IP which has access. Now i am not able to access the router web interface and i and my router reset button is not working. Please help me.
