Whirlpool Calypso GVW9959K Top Load Washer Logo
Posted on Oct 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Machine fills w/water quits flashes lb? lz? - Whirlpool Calypso GVW9959K Top Load Washer
Arturo D'Souza
Level 2:
  • Expert 133 Answers
  • Posted on Oct 08, 2009
Arturo D'Souza
Expert
Level 2:
Answers
133
Questions
0
Helped
66496
Points
318
There is a water pressure switch that operates when the required water fills in the tub. this pressure switch in your machine is possibly faulty. In ur case the water keeps filling then it detects an error and stops that's when the lights start flashing. the pressure switch fails to detect the amount of water in the drum and so the machine doesn't move on to the next cycle
tip
Porteus on a MultiBoot USB Flash (Grub4DOS)
Porteus is a linux distribution customized for USB flash
and disks (live mode)
It is available as 64bit and 32bit solution
to install on USB flash, CD, MP3 player, camera and hard drive.
Porteus 32bit
1.) Download the Porteus 32bit ISO image:
http://porteus.org/index.php#
2.) Create a folder porteus on a USB flash drive.
3.) Take from the downloaded ISO, files
vmlinuz
initrd.lz (from the folder boot)
and all content (from the folder porteus)
will be placed in a folder porteus.
(extract the files from the ISO can programs Ultra-ISO or WinRar)
4.) In the main menu.lst add a:
title Porteus ==>
configfile (hd0,0)/boot/menus/porteus.lst
5.) In the folder /Boot/menus/ (Create a folder on a USB flash drive)
to file porteus.lst (Create a file on a USB flash drive) add:
splashimage (hd0,0)/BOOT/Splash/slacktux.xpm.gz
foreground 000000
background ffffff
timeout 30
default 0
title Porteus Graphics mode (KDE)
find --set-root /grldr
kernel /porteus/vmlinuz max_loop=255 ramdisk_size=6666 root=/dev/ram0 rw autoexec=xconf;telinit~4 fromusb
initrd /porteus/initrd.lz
title Porteus Graphics mode (KDE),Copy To RAM
kernel /porteus/vmlinuz max_loop=255 ramdisk_size=6666 root=/dev/ram0 rw copy2ram autoexec=xconf;telinit~4 fromusb
title Porteus Graphics mode (LXDE)
kernel /porteus/vmlinuz max_loop=255 ramdisk_size=6666 root=/dev/ram0 rw autoexec=lxde;xconf;telinit~4 fromusb
title Porteus Graphics mode (LXDE),Copy To RAM
kernel /porteus/vmlinuz max_loop=255 ramdisk_size=6666 root=/dev/ram0 rw copy2ram autoexec=lxde;xconf;telinit~4 fromusb
title Porteus Graphics mode (KDE) + Save changes /porteus/
kernel /porteus/vmlinuz max_loop=255 ramdisk_size=6666 root=/dev/ram0 rw autoexec=xconf;telinit~4 changes=/porteus/ fromusb
title Porteus Graphics VESA mode
kernel /porteus/vmlinuz max_loop=255 ramdisk_size=6666 root=/dev/ram0 rw autoexec=telinit~4 fromusb
title Porteus Text mode
kernel /porteus/vmlinuz max_loop=255 ramdisk_size=6666 root=/dev/ram0 rw fromusb
title Return Back <==
configfile (hd0,0)/menu.lst
title Reboot
reboot
title ShutDown
halt
5.) Download file
http://dl.dropbox.com/u/4040651/slacktux.xpm.gz
Put the file in a folder /Boot/Splash/ (Create a folder on a USB flash drive)
6.) Porteus on our MultibootUSB flash-is ready for operation.
INFO: MultiBoot USB Flash - Survival Guide (Grub4DOS)
http://www.fixya.com/support/r8170992-multiboot_usb_flash_survival_guide
on Feb 07, 2011 • Computers & Internet
1helpful
"Check inlet/outlet indicator light" flashing
If he has takin the fill hoses off the unit and tested them for flow and the filters on the water valve are clean, then yes the fill valve would need changed.
Scotsman ice machine slow water fill
Check to see if there is a water filter inline if so then change it. If not then check where the supply water line is hooked up to the machine pull line off and turn water on to make sure you have good water pressure. if you have good pressure then pull the water inlet valve and take it apart to make sure it is not stopped up with trash and that is it.
Why does water not shut off after making ice
Is the bin drain line and dump drain line tied together. If so then it is melting ice from the bin. now when ice machine starts up it will dump the old water in sump tray so it will be fresh water during new freeze cycle.
How To Format memory card
first plug in memory card into your PC ,next go to computer to see if the card is on there , then find the menu, press Format, and you should not get patriot next time, get sandisk because it is water, temperature, shock, and x ray proof.
Recipes for b&d breadmaker model 2300
Knowing your breadmaker's loaf capacity will enable you to find recipes of any variety on the Internet for free.
It will also keep you from adding too much ingredients which could cause dough to over-rise and spill onto the heating element.
Remove your bread pan from your breadmaker. Using a one-cup 8-fluid-ounce liquid measure, fill your bread pan with water. As you do, count the number of cups it takes to fill your bread pan to the very rim.
Generally speaking...
If your bread pan holds 7 & 10 cups to the rim then you have a 1.0 lb or 500 g loaf pan
10 & 11 cups to fill = 1.5 lb (700 g) loaf pan
11 & 13 cups to fill = 2.0 lb (900 g) loaf pan
13 & 15 cups to fill = 2.5 lb (1250 g) loaf pan
15 & 17 cups to fill = 3.0 lb (1350 g) loaf pan
A bread recipe for use in a 1.0 lb (500 g) breadmaker should never exceed 2-1/4 total cups of flour.
1.5 lb (700 g) = 3-1/4 c
2.0 lb (900 g) = 4-1/4 c
2.5 lb (1250 g) = 5-1/4 c
3.0 lb (1300 g) = 6-1/4 c
Warning: When testing a new bread recipe it is always best that you not leave your breadmaker unattended. Stay close by to monitor its progress from time to time.
Did this answer help? I hope so. Please rate it as soon as you can. Thank you.
Lost manual need to know if the trilium TR 500 breadman is a 1 lb or 1 1/2 lb machine and directions. lost the manual
Bread pan Capacities
Here is how you determine the size of loaf you can bake in your machine. You need to determine the capacity of your pan. Fill your pan with water and measure the cups added so you know how many cups of water are in the pan when it is full to the very top. Here are the conversions:
1)If your pan holds less than 10 cups of water you can make: a 1 pound loaf
2)If your pan holds 10 cups of water you can make: a 1 pound loaf and a 1.5 pound loaf
3)If your pan holds 12 cups you can make: a 1 pound, 1.5 pound, and a 2.0 pound loaf
____________________________________________________________________
This is rare, but if you pan holds 14 cups or more you can make all the above plus a 2.5 pound loaf
FROM ANOTHER SITE:
To find your bread machine pan size:
Fill the bread pan with water and measure it out in cups
Less than 10 cups of water = 1 pound
11-13 cups of water = 1 1/2 pounds
More than 13 cups of water = 2 pounds
My whirlpool front load washing machine accept hot water and no cold water entering on the machine.
The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
