i have lost the paperwork to this remote. model pm4355s, c1034. please send code for a sylvania tv, connected with dishnetwork. i need the input button to play games, dvd, etc. [email protected]. i have lost the paperwork to this remote. model pm4355s, c1034. please send code for a sylvania tv, connected with dishnetwork. i need the input button to play games, dvd, etc. [email protected].
Yes, I have the same problem - lost the sheet showing codes and therefore, unable to set-up the remote.Yes, I have the same problem - lost the sheet showing codes and therefore, unable to set-up the remote.
AnonymousJan 20, 2009
need codes for a sylvania television using a phillips universal remote need codes for a sylvania television using a phillips universal remote
AnonymousJan 25, 2009
I NEED CODE FOR MY SYLVANIA TV I HAVE A PHILIPS UNIVERSAL CONTROL MODEL #CL015 I NEED CODE FOR MY SYLVANIA TV I HAVE A PHILIPS UNIVERSAL CONTROL MODEL #CL015
how do i put codeinfor tvhow do i put codeinfor tv
AnonymousFeb 08, 2009
i actually didn't have the code and i want the code because i want to play my x-box.i actually didn't have the code and i want the code because i want to play my x-box.
AnonymousMar 29, 2014
we lost the remote control and owner manual..want to connect it to our samsung tv for surround soundwe lost the remote control and owner manual..want to connect it to our samsung tv for surround sound
You can't post conmments that contain an email address.
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4.
Press the Channel Up button repeatedly (up to 300 times) until the
device could be controlled changes channel. The red indicator blinks,
then stays lit. If you accidentally overshoot the code required, press
the Channel Down button to backtrack through the library until the
device changes channel. Pressing Channel Up changes direction to
forward again. Press and release the Mute button to install the code.
Manually turn on the device you want to control 1. press and hold the CODE SEARCH button til the light stays on release the code search button 2. Press and quickly release the desired button ( TV, DVD, etc ) the red light blinks off once 3. Press the CHANNEL UP button repeatedly ( up to 300 times ) til the device changes channel and stop (the red light will blink off after each time the channel up button is pressed ) 4 Press the MUTE button to set the code
I can't find the code for the phillip remote to my emerson tv
lost code book dont known what buttons to push to search for codes
need code for phillips remote for a zenith tv
I need the code for the same tv. I lost my sheet with all the codes on them.
i need the codes for the tv so the remote will work
I dont know how to find the codes either...:(
I have lost the code the remote only gives a red flashing light but doesn't get the TV on
Appreciate your help.
