Belling XOU592 / XOU593 Electric Double Oven Logo
Posted on Dec 24, 2007
Belling synergie. oven does not heat up. grill ok. think i need to set to manual but how???
  • 2 more comments
  • 2pints Feb 29, 2008
    fan working in main oven but not getting hot, eliment at back doesn't seem to be working. how do i take out to fit replacement ? or could it be something else? thank you....
  • elaine_buckl Aug 25, 2008
    cannot disconnect the automatic timer and oven will not function
  • Anonymous Apr 06, 2009
    had exactly the same problem with the flashing auto, thanks
  • Anonymous Mar 17, 2014
    Cant set clock and the bell keeps pinging
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 19, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
4029
Points
9
If its flashing auto.
Press and hold the 2 buttons on the left hand - clock and cook time and then press the + button.
This then sets the time to allow manual and takes the auto off.
cheers
will
Anonymous
Level 1:
  • Posted on Apr 14, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
4029
Points
6
Had the same problem with Belling Synergie, grill ok , oven light on (thermostat) but no heat. Also trip switch went at same time so presumed it was element. €30 element from electric shop and changed it in 15 mins. Remember to switch of mains. Access to element from inside oven, remove four back screws and bolt securing element. Element pulls out and remove the push fix connectors. Replace element and refit.
Anonymous
Level 1:
New Friend:
  • Posted on Apr 04, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
4029
Points
Oven nor grill wont heat up and the light is on so thats ok so have i to take it off auto?
Manual needed for belling multifunction synergie 50/50 oven
You can probably order a manual from the manufacturer. But if all you need is a schematic, check out the internet. Sometimes the manufacturer places a diagram right on the back of the device or in an envelope inside the cover (but not always!).
2helpful
Replaced element on belling synergie on 2 occasions in the past 6 months. What could be the reason for them blowing?
fan on in oven but not heating up just after the power tripped think because of oven this is not the first time this has happened can you help please
yours shane
1helpful
No heat in oven
check that tthe cable connection to the elements is ok and not burnt and that the power is at this terminal, if present then change the element and if absent then check and change the the thermosatrt
Jul 13, 2010 • Ovens
Belling synergie oven grill comes on oven fan comes on all lights are working but no heat in the oven temp 200 setting on the oven symbol all plugs have been checked.
I suspect tha the oven element is faulty.
To access it, you will find it located at the rear of the oven compartment behind a removeable cover.
Hope this helps you.
10helpful
Fan oven wont heat up
If fan is workintg, but no heat, then replace oven element.
If no heat or fan, then make sure timer is set on manual and not on auto
Please rate my solution.
Thanks.
1helpful
2answers
How do I find the model number on belling synergie oven?
I have the same problem. I have inherited a Belling Synergie multifunction double oven. The Model No is worn out - yet there is a specification 492SS which isn't. I am going to purchase the element with this number and hope this works.
Faulty Oven
Have you tried www.appliance-parts.co.uk, they have a useful parts finder service.
Nov 30, 2008 • Ovens
1helpful
2answers
Belling Synergie
NEED NEW FAN OVEN ELEMENT THAT CAN BE FOUND HERE
You need Element code AB20 on link below
http://cookerandovenelement.co.uk/bellingfanovenelement.html
element is located on back wall of oven you need to pull oven oven to remove the element element is held by two nuts from back and i screw from front
6helpful
2answers
Belling Synergie fan oven.
the elemet has burned out round the fan
Top Belling Ovens Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
David Spradling
David Spradling
Are you a Belling Oven Expert? Answer questions, earn points and help others
