Sony Playstation 3 (PS3) Console Logo
Posted on Oct 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Upgraded ps3 to firmware 3.01. Now my ps3 will not play blu-ray movies or blu-ray games. Any suggestions
Anonymous
Level 2:
Champion:
  • Expert 241 Answers
  • Posted on Mar 23, 2010
Anonymous
Expert
Level 2:
Champion:
Answers
241
Questions
0
Helped
49886
Points
369
Try these http://www.youtube.com/watch?v=Gp5FoFKEltg&feature=related http://www.youtube.com/watch?v=_r1AebrHVEk
2answers
Playstation 3 not playing games but will play blu ray discs
Make sure that your firmware is updated correctly. Also make sure the games are the correct region for the unit you're playing on. You may have an incorrect region setup on the PS3. PS3 games are region locked, either being PAL or NTSC. If the PS3 is set to read PAL (by being set to a region that is PAL, like the UK, Europe, and Japan) it will not read or play an NTSC disc.
Misconfigured or corrupted firmware installations can also cause this problem. Furthermore, pirated games will not play, because they do not have the appropriate security key on the disc.
You can try testing this by creating a new profile on the PS3 and trying to play the games. If you can play them with the new profile, then there is a corruption with the old profile. If you can't play them in the new profile, then it could be the firmware.
Lastly you may have a blown drive. Most PS3 games are dual layer blu ray discs capable of storing large amounts of data. The blu ray drive in the PS3 uses a sequenced dual laser to read the game. If one of the laser emitters has blown, it won't read the game correctly. However, since it doesn't use both emitters to read blu ray movie disks or dvds they'll still play correctly.
3answers
Ps3 slim blue ray won't play can't find settings
Will it play anything? The laser eye may need to be cleaned. Sometimes the drive will play DVDs but not games, or games and bluray movies, but not DVDs .... in that situation, the bluray laser may need to be replaced
2answers
Cant play blue ray movie. wants to system update. how does this work
There are some firmwares that support playing movies on the game, if the files are not complete, then the ps3 will not be able to play any movie, and some times it might affect game discs as well.
So when next your playstation 3 wants to system update, allow it, so it will automatically restore the files that are necessary to play a blue ray disc.
Systems update is done online, so you must have an internet connection either wireless or by connection for the playstation, and if it pops up the system update message next time, allow it. It will install new firmwares for the playstation 3 and you will be able to enjoy better services on the game.
Take care and good luck
Hope this was helpful
3answers
My ps3 will play ps3 games but not dvds. it loads the dvd then turns black. Any suggestions?
You can follow below steps to play DVDs on PS3.
Step 1: Insert Blu-ray disc into PS3's Blu-ray drive. Playing Blu-ray disc movie works exactly the same way as entering a game, except you need to head into the Video Tab in your PS3's home menu, rather than the Game Tab. Highlight the Blu-Ray and press X to start it immediately.
Step 2: Now the Blu-ray disc will load like a traditional DVD. Use your controller to access the menu, and use the D-Pad to select your option and press X to enter. When the media is playing, you can press triangle to open a mini-menu that will give you access to options such as subtitles, audio channels and volume. You can also access the main menu, using the arrow keys to navigate. Press triangle again to close this menu.
However, if you can't do it successfully, try to convert DVD to regular video and transfer to PS3.
Step 1: Download and install Leawo Blu-ray to PS3 Converter, and then launch it.
Step 2: Get source Blu-ray movies ready. Insert Blu-ray disc to the Blu-ray drive, or get source Blu-ray folders ready for loading and converting.
Step 3: Load Blu-ray sources
Click "Add Blu-ray/DVD" button on the program interface. This Blu-ray to PS3 converter would then guide you to browse source Blu-ray movies for loading.
Note: After loading source Blu-ray movies, you could select subtitles and audio tracks, play source Blu-ray movies, edit Blu-ray movies, snap screenshots, etc.
Step 4: Do output settings
Next to the "Add Blu-ray/DVD" button, click the dropdown box and select "Change". You will then arrive at the Profile setting panel to select output format from "Format" group or "Device" group. Select "MP4? from "Format" or directly choose "PS3? from "Device > Sony".
Optional settings: After you've set the output format, click the same dorp-down box and click "Edit" option and then you could adjust video and audio parameters of selected profile, including: video codec, audio codec, bit rate, aspect ratio, frame rate, channel, etc.
Step 5: Start converting Blu-ray to PS3
Back to the main program interface, click the green "Convert" button. You could then set an output directory on the right popup sidebar. After setting output dirctory, click the below convert button to let this Blu-ray to PS3 Ripper instantly start converting Blu-ray to PS3 videos.
Note: Internet connection is required during the whole conversion.
After you convert Blu-ray to PS3 friendlier videos, you can transfer the videos to PS3 and then start to play Blu-ray on PS3 in a indirect way. For details, you can read the extension part.
For more details, check: Direct and Indirect Ways to Play Blu-Ray on PS3
4answers
PS3 will play games but not movies
Well if the regular dvd's dont work.. I would recommend you to buy Blu-Ray movies instead.. PS3 is the best known blu-ray player. buy at least one blu-ray movie and try that.
My ps3 plays movies but wont recognize games
The PS3 uses a different laser for DVD's, Blu-Ray disks, and CD's. It's quite likely that just the Blu-ray diode has crapped out. have you upgraded to firmware 3.10
For the player to work perfectly the lens needs to be clean. One piece of dirt can cripple your PS3 and end up with your PS3 not playing games. This dirt needs to be cleaned off the lens occasionally to avoid you having ps3 problems loading games.
Try these steps to resolve this issue:
You could be facing a lens related issue or corrupted firmware problem
try this
1. Update your firmware (if you aren't running the latest already). Yup, this overwrites some of system software that may have been corrupted.
2. First, back up your game saves, and any music you have on your HDD. Format your PS3, this fixes corrupted files on the HDD by forcing the PS3 to rewrite them.
3. Try cleaning the blu-ray drive lens with a Blu Ray Lens Cleaner
if this does not help, i suggest should be send to Sony for repairs in case your PS3 is under warranty your replacement drive may be covered still you need to check with PS3 customer support, Laser replacement would cost you around $130.
Hope this helps, and please do rate my solution, Happy Holidays and Happy gaming ahead!
Regards
KreativeGeek
2answers
Ps3
try setting the console back to factory settings, i had the oposite problem, would play games but not movies. will it play blu-ray movies or regular? if it doesnt play blu-rays, your disc reader may have gone bad.
4answers
Ps3 plays video games, not bluray movies or dvds
I would start with a firmware update (2.60) and also a full system restore. That should fix the problem. Let me know. I'm a PS3 expert!
Blue ray movies
Is there a firmware update for the PS3?
You might google for this and check a link like the following:
http://www.blu-ray.com/firmware/firmware.php?id=2
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
